I problem fixed. Another issued surfaced.
Can someone tell me what this is that just started leaking. It's never leaked before. Just walked out in the garage to check things over and notice a puddle on the floor from this source:
It's just to the rear of the tire I just changed on the front passenger side
Yes, the vice grips are mine, unless Chris wants them for his cookie jar displays that show all the stuff they have pulled from tires (razors, bolts and now small vice grips). I did have a spare km2 and I'm going to take the wounded soldier ti Chris for fix or replace) .
The leak culprit is this little open air hose which comes out I
Of the fire wall and points down right on top of those heater lines (I turned it side ways so you can see it better. I can't see or feel anything (like a fitting, etc..) that it should be attached to and has come loose. Weird.
. Big, clear, tasteless, alarmingly large puddles are just the water running off your AC coil. (Assuming you are running the AC)That AC condenser. Stop being a spaz
What was the tire diagnosis?
#winningIt will probably be fine. Not in sidewall. I got to Chris's store and said screw it and and just kept going a little further south on 49 until I ended up here:
