Registry 60-series Registry
Vehicle Registries
1. Year and model of vehicle: 1984 FJ60
2. Name of owner: Ahmad (or Ki)
3. Name of vehicle (optional): SpaceG (SpaceGodzilla/Gojira)
4. Mileage on the truck odometer: 198,893 MI
5. Modifications, if any: None from myself (a few from PO).
6. How you use the truck: I plan to use it as a camper of sorts…
7. A single photo:
85 FJ60
Branden
Undecided
200750
Desmogged, little lift, roof rack, front bumper with winch.
Got a deal from a good friend I absolutely could not say no to. Ole girl has been rode much in the past six years so working on getting the neglect out of her. Did already changed the oil pan gasket and fixed the exhaust. Have everything to redo the front end this weekend. Been a jeep guy but I'm already in love with this thing.
An informal registry for FJ60’s, BJ60’s, and HJ60’s of all types – yes. 61’s and 62’s included… This will be a sticky thread.
Rules of order – ONLY ONE post per vehicle – no comments on the thread or you will have me editing – which resembles work, to which I am averse.
What I would like you all to post… and please keep it brief, OK?
2. Name of owner
7. A single photo
2. Name of owner
7. A single photo
1985 Toyota Land Cruiser FJ60
2. Name of owner:
 Gabriel
3. Name of vehicle:
Bodhi Wagon aka Bodhi Yoti
4. odometer:
 200,363
5. Mods: Old Man Emu suspension, 33” BFG KO2. Otherwise largely stoxk.
Recently purchased after a long search. It’ll be a weekend driver, road trip truck, dog hauler, and excuse to take the long way home. The goal is to preserve it, sort out the small issues, and keep it on the road for another 40 years rather than turn it into a show truck.
The picture to the left is our Toyota Tacoma camper, see
Our FJ60 is pictured far below.
Color is Blue, 8B2
Purchased ~1988 w/~25,000 miles on it. Now 225,000 miles.
Following maintenance was completed over the 38 years I have owned it.
Wheels, added five 16 inch Toyota replacement wheels for FJ60 (powder coated gray from Toyota): Per Dan Busey @ L/C Museum, Salt Lake City, UT: part # 42601-60262-03. For excellent chroming, shipped to: California Chrome Wheel. Fitted with new Patagonia tires, Dec 2025, ~48,000 miles on new odometer.
Rebuilt engine @ ~149,000 miles, milled the head for more compression
Added headers
ARB rear locker.
Limited slip in front axle.
National Luna fridge on slide, on top of ARB drawer system
Lifted ~2 inches.
Added H55F five speed trans
Ramsey winch
Ice blasted and undercoated
Ceramic coated
Driver's seat rebuilt with original material.
Desmoged engine
Work by Leading Edge Automotive, West Chester, PA from Sept 2024-Dec 2025:
New 80 series steering box w/105 sector shaft. Saginaw power steering, now upright.
Rebuilt & painted front drive axle parts + added new chrome molly Birfields, + all new bearings and seals.
Added wedge shaped aluminum triangles to rotate the front axle to allow proper front end alignment.
Air leaks, added proper air hose
Anti reversal spring mounts.
Added 4 cig lighter (one cig lighter is HOT all the time) and 2 USB/C ports.
Cleaned up all wiring, under hood + dash in cabin.
Ignition system parts, wires, plugs, coil, harness, ign module, rotor bushing, etc.
Lithium Ion house Battleborn battery.
Phone mount/charger on windshield
Wiring for winch, new.
Rear diff gears, re-newed & new ARB locker
Oil pan, new (original paint on the interior was flaking off and circulating in the oil)
Tie rod ends, new
New rear brakes, drums, wheel cylinders
New after market LED headlights
Sniper fuel injection, adjusted and updated it
Tires: Installed five Milestar Patagonia A/T PRO, LT265/75R16? tires, new center caps.
Wipers
Phone mount
Fuel lines by Aeroquip, fittings
V-belt, high capacity
Sway bar link hardware, proper size
PCV valve & breather
Body mounts, 24 + fasteners, new. Had to move the body off the frame.
ARB compressor, dual, + air lines, replumbed wiring
Adjusted Holly Sniper system.
New aftermarket headlights
Wiring throughout, replace & clean up
Oil cooler seals
Cooling system hoses
Side markers
Alignment, custom
Driveshaft, front, custom double cardon, new
Battery, starter, Odyssey extreme duty AGM, BCI No. 34M, new
Battery, house, new.
Tie rod ends
Fluid service, F/R diffs, transfer case, trans
Radio, GMRS, in place of CB radio
HEI coil, spare is in vehicle
Rotors, front
Shocks: Four new Dobinson IMS shocks installed ~May 5, 2026 by Leading Edge Autosport. The Dobinson shocks are awesome!
ARB drawers added years ago
Dual battery system: The summer 2017 issue of Overland Journal did a study of dual battery systems; they did not like the National Luna system for the same the reasons I did not like it, instead they recommended the Intelligent Battery System
Which is now installed and it works great.
Chrome: For top-quality chrome plating of new car wheels in the U.S., a few companies are widely recognized for excellence:
• California Chrome Wheel (California) – Famous for their triple-plating process (copper, nickel, chrome) and very high-end finish. (I used them to chrome plate my new wheels from Toyota, installed Dec 2025.)
1984 BJ60
Gregory
Bluemagoo formerly "marshmallow"
550,000 and climbing
ome lift 3 inch heavy rear 2 inch heavy front, 50mm flatout offroad body lift, front leveling firestone riderite air bags, axt turbo kit, 2.5 inch stainless 304 exhaust, 3 inch stainless 304 snorkle, frp fender flares, 3xm lift up windows, 35x12.5x15 g003,arb side protection steps, rear tire carrier/ fuel carrier, arb front bar with 8274, ipf fog led fog lights, lensun hood solar pannel ,lund windsheild visor, vhf motorola radio with almosa antenna
all year round daily
1. Year and model of vehicle: 1987 FJ60
2. Name of owner: Cliff
3. Name of vehicle (optional): Still working on it.
4. Mileage on the truck odometer: 187,438 MI
5. Modifications, if any: De-smog. Stock fit wheels/tires(not pictured).
6. How you use the truck: Weekend country cruiser.
"Still working on it " is a great name for an old Cruiser.😎
