60 series p/s conversion
Greenfield, MA
Website
thecarpentryway.blogspot.com
Hello all,
well i've scoured the tech links on the topic of power steering. I'm converting my rig from RHD to LHD and will be looking to install a power steering gearbox. First of all, before everyone chimes in with "go saginaw", I have ruled that out becasue I'm also going to fit a pto, and it doesn't work with that.
Going to 'stock' 40 series power steering is one option, but anyone looking at 60 series steering gear can readily see how much more simple and direct it is, and how it is beefier than the 40 series gear. The 'big problem' with going to a 60 series gearbox seems to be the shock tower, which looks to be partially in the way of the steering shaft. No way am I going to cut my stock tower off and stick some Ford tower in there. I want to go Toyota all the way if possible. I saw Pablocruise's thread, and he went with a welded in mounting plate, which moves the box ever further into the line of the tower. I'm planning to drill right through the frame on both sides, insert support tubes, and bolt the steering box right on to the frame, just like factory on the 60's. So, how much room is there to play with? Why not grind a clearance in the back web of the shock tower support and weld on another support piece onto it to make up for any loss in strength?
It seems like the inner fender would need some sheet metal welded in to cover the opening where the original gearbox pitman arm pokes down...any advice?
:cheers:
Why are you making things harder than they need to be? There really is nothing special about that shock tower. Replace it. If you can't stand the idea of a piece of steel that is sold to you by FoMoCo, fab something.
Mark...
Yes, I will cover the orig opening for the 40 series gear when I put on new fenders.
I wanted to do the conversion with my old crappy fenders so I would know where to cut for steering box and shock towers.
I have seen people notch the 40 towers. The Ford F250 towers give you longer travel though, so I went with them.
I also thought about sleeving the frame for a mount, but access is tight on the inside of the frame rail. This is why I went with the plate. It also move the box away from the radiator mount.
Good luck!
PS: Why convert from RHD to LHD?
Good luck!
I didn't plan on converting the truck from RHD to LHD when I bought it, however in the course of digging into bodywork problems with the front of the cab, which were numerous, it became apparent that it would be the same/less amount of work to put an entire new cab bulkhead in. And then I came across Sea potato's cab bulkhead. You might want to check out my thread in the FJ45 section of the forum.
While I was not apprehensive at all of driving a RHD truck in a LHD country, and have driven in both LHD and RHD countries extensively, it was still a slight negative to to the truck in my view. If I ever want to resell the truck, it will be easier to find a buyer for a LHD version, and there are a couple of driving situations where it is not advantageous to be on the 'wrong' side of the cab, like turning left against traffic, and passing. Most driving this truck will see will be on the road, so i want it to function as well as possible in that environment, which might also include the odd drive-through situation.
I finally got a tie rod puller today and got a 60 series manual steering box from a donor and, after stripping the gearbox, pump, pivot arm, etc, on the 47, and chopped off a fabbed up pto mount, I took a look at how the 60 series box fits up near the shock tower. It looks do-able without cutting too much into the shock tower. I imagine the cast tower can be heated up and a little reinforcement pieces or two welded in? I have the vague idea that welding cast is a bit tricky - anyone have any tips?
I need to get a hold of a power steering 60 series box to see if the box casing is different and how that affects the situation.
If space is tight for your application there are 2 different shafts that I have found attached to FJ60 PS boxes. One is a solid shaft that is splined at the U-joint attached to the box, the other uses a larger diameter collapsable tube. The solid shaft might give you an extra 1/4" of clearance if things get tight. If you don't want to put the plate against the frame and would rather mod your radiator support then you should be able to work around the shock tower. It just depends on where you want to put your efforts.
The steering is pretty nice when done. Good luck.
Yeah, the manual box I checked out today had the solid shaft splined, with a u-joint assembly clamped to it. I'm hoping to find a power steering box the same. Didn't know there was another type though, so thanks for that piece of info.
I hadn't considered going further forward of the shock tower into the radiator mount area. Do you have any pictures of a truck with that mounting?
I used a set of 2" extended shock towers from man-a-fre. Re-located the driver side tower rear-ward towards the cab and flipped the shock pin pointing forward. Notched the inside of the shock tower and mounted the steering box close to it bolted through the frame. Used fj55 steering column shortened 1". Cut fender out to fit around the box. 1.25" DOM mini truck tie rod from Marlin. FJ60 TRE's. FJ60 knuckles and arms. There are countless ways to connect the steering box to knuckles covered here and elsewhere. I also have a manual box which is interchangeable with an early 80's ps box. Disclaimer - this is my first build up and still in progress. Good luck.
search the FJ55 forum for FJ60 power steering, there is a couple of recent threads with some good pics...might give you some ideas.
Whoa, some more ideas there I hadn't considered! Makes sense - I'll check into those man-a-fre shock towers, though after wrestling the old steering box mount off the frame yesterday, I'm not too psyched about removing another riveted-on component;p
I found the easiest way to get rivets out was to drill them. Use a small pilot hole (1/16?) all the way through. Then 1/8" most of the way through. Then a large drill to take the head off. Insert an 1/8' punch until it bottoms out in the 1/8" hole and drive it out. The metal is very soft.
I have just finished looking at the Scout II/saginaw box conversion thread. The Scout/saginaw box is a very similar configuration to the Toyota 60 series box. It's another decent option, but the drawbacks seem to be:
-non-Toyota
-power steering hoses that need to be metric one end and imperial the other
-doesn't have the relatively easy bolt in 60 series w. 55 column situation - instead more fabing is neccessary.
On the plus side, the mounting looks a little simpler with the 3-bolt mount in the Scout II instead of the Toyota 4 bolt. I can't tell from pictures which box has the greater offset over the top of the frame rail.
What about cutting the vertical part of the pump mounting off and rewelding it on so as to space the gearbox over towards the engine far enough so that no mods to the shock tower are neccessary? I just don't know about cutting and welding cast.
I found it extremely east to get the rivets out. An angle grinder will make short work of the head. Make sure there is no *flange* but only the width of the bolt in the frame.
take a 1/4" round punch and a hand sledge. Knock the rivit into the frame rail.
extract the rivit or just wait for it to fall out on the road somewhere... :D
-non-Toyota
I don't see why non-toyota is a minus if the part is better. I would have gone scout over my FJ60 conversion if I could have found a box.
The metric/imperial thing is a load of bull$hit. The flare fitting is the same for saginaw boxes and pumps, and toyota boxes and pumps. I use an FJ60 high pressure line between a saginaw pump and toyota box. It works vice versa as well.
There is an easier/cheaper way to adapt any box to the FJ40 steering column without the hard to find FJ55 parts. I just cut off the ragjoint connection at the end of the shaft, slipped on a pillow block bearing, and bought a smooth bore Borgeson steering u-joint that slipped on the shaft, drilled and pinned with a 1/4" grade 8 bolt. You could do the same for the scout box.
Don't be afraid to think outside the writeup. There is more than one way to get everything done.
Not sure what you're talkin about cuttin and moving. I mounted my FJ60 box directed to the side of the frame (boxed the other side for 10" and sleeved the bolts). All I had to do was grind on the inner rib on the shock tower and notch the front of it. The best option is to just remove the stock shock towers and install some Ford F250 ones.
Keep in mind the scout box is more powerful and stronger. I don't think you
'll find one is anymore work than the other.
Yeah I hear you. i don't know what I was thinking with the cutting work I was envisioning on the 60 steering box. When I went and took a look at mine, I ruled that out right away.
As far as which is better, Saginaw or Toyota, well I'm sure that most would agree on the stonger/more powerful part of it, but there are other points to consider. Now that I've come across a bunch of different possibilities as far as the pump goes, I'm keeping an open mind.
I'll take your word on it as far as interchanging hose fittings between Japanese and American components.
I have also noticed that the radiator support is involved in this equation. I'm not going to go for the Ford shock towers. Ford is not a company I support if I can help it.
