60 series aircond modernisation / refresh!
Western Australia
Gday all!
Over the past 8 or so years of my current hj61 60 ownership, I have put up with, troubleshoot, repaired, and made a lot of excuses for poor airflow and aircond performance in hot weather… a few months ago, I decided to fix this - properly….
A bit of history (most of this is already on Mud under various headings of what I did over the weekend / help me threads / what do you think threads!!)
First, there wasn’t much air out of the vents… I sucked a lot of stuff out of the evaporator with a garden blower in reverse through a hole I cut in the fan side of the evaporator box! - this did improve flow! And stayed like this for a couple of years… then the fan started playing up. I replaced bushes / turned the commutator on a lathe / sanded / cleaned etc, but in the end I bought a new, genuine fan from Leon Caitlin in Aus… next, the aircond really struggled in hot weather - basically not working at all at idle and not much better at high speeds (this is in mid to high 40degrees Celsius temps). I decided on a new parallel flow condenser - recommended by Mr Landcruiser which required stripping the front of the car, customer brackets to mount it and new aircond hoses. I showed my aircond guy the condenser and he made up hoses with connections on one end and extra hose on the end. This ended up okay, but not ideal as I had to flip the condenser to clear other bits (aux battery tray / Intercooler piping etc)
Next, I tried to install a new tx valve and pressure switch onto the existing hole I cut in the evaporator box. This didn’t happen and I decided I needed a new evaporator (ordered a new Jayair one through Leon Caitlin and a new genuine tx valve on eBay. The evaporator box came out easy enough - apart from my after market wiring that got in the way… the old bs new shows a bit of difference!
From there - new closed cell seals - with extra super glue on the sticky back to help, and it all went back in. Another trip to my aircond guy to connect the ends to the hoses (and a new dryer from a Ford Falcon which is larger than the original). He regassed it with 134a, which he got (from memory) 750grams into it - apparently very good compared to stock - but I have no idea of this…
It certainly blows a lot of air now, and is so cold my hand hurts when held close to it! Hopefully the coldness stays around back up in the mid 40-degree temps!!
Thanks!
Drew
Thanks for posting your story up. How was the Jayair evaporator to install? Did it need any tweaking or modification?
Toyota/Denso have discontinued the evaporator for right handed 60s, so AFAIK it's the only alternative.
I've got a used unit coming to me from Japan which in pictures looks to be in like-new, but if that's no good, I'll be ordering a Jayair unit. My existing one came from AUS used and looked just like yours, with 35 years of red dust and dog's arse corroded into the fins.
The Jayair evaporator fitted perfectly! Very tight in the evaporator box though!
Thanks, that's good to know. Looks like a quality unit.
The blower unit that you got I believe is for a 70 Series, was that a straight fit? Was it Denso or Toyota branded? If you have it, the part number would be very helpful, thanks.
Blower motor photo - Denso on it… am unsure if it is for a 70 Series - but fit and identical to the one that was replaced…
As far as what it cost me…. The condenser, evaporator and tx valve were all purchased by me through different vendors for (this is all approximate - from memory, without me going through invoices etc) $800 AUD. The custom hoses / end connections / installing the tx valve and pressure switch within the evaporator (and cost of pressure switch), as well as re-gassing the system with 134a refrigerant cost $350 AUD… By the time closed-cell foam for the vents, steel sheet for the condenser bracket and other minor bits, it is probably $1300 AUD - without any running-around costs or the weekends I have spent mucking around getting it done!!
Worth it though!!
Gday all!
First, there wasn’t much air out of the vents… I sucked a lot of stuff out of the evaporator with a garden blower in reverse through a hole I cut in the fan side of the evaporator box! - this did improve flow! And stayed like this for a couple of years… then the fan started playing up. I replaced bushes / turned the commutator on a lathe / sanded / cleaned etc, but in the end I bought a new, genuine fan from Leon Caitlin in Aus… next, the aircond really struggled in hot weather - basically not working at all at idle and not much better at high speeds (this is in mid to high 40degrees Celsius temps). I decided on a new parallel flow condenser - recommended by Mr Landcruiser which required stripping the front of the car, customer brackets to mount it and new aircond hoses. I showed my aircond guy the condenser and he made up hoses with connections on one end and extra hose on the end. This ended up okay, but not ideal as I had to flip the condenser to clear other bits (aux battery tray / Intercooler piping etc)View attachment 4042021View attachment 4042026View attachment 4042027View attachment 4042028View attachment 4042029
Does Leon Caitlin have a website to get in touch? Needing an evaporator for FJ60 like yesteday. Looking for the best replacement for my 86 60. Thanks
Australian cars are right handed, so the Jayair condenser will not fit a left handed US vehicle, which I assume you have.
I need to do the same before summer as I'll probably be moving back to the edge of the desert in SA and no AC in the glasshouse that is the 60 series definitely isn't the vibe... The AC hasn't run as long as I've owned the car, so fingers crossed all it needs is a few new O-rings and a re-gas, but I'm preparing for the worst, so I really appreciate you laying out what you did and the costs - I'll definitely refer back to this.
A couple of questions:
1) You said Mr Landcruiser recommended the parallel flow condenser. I've heard the same, and see he now sells what looks like the same one with mounting brackets for the 60, so hopefully that should make install a bit easier. He also sells a condenser + expansion valve combo (both aftermarket), but I'll try to chase up a genuine expansion valve.
2) Where'd you get the pressure switch? OEM or aftermarket?
3) Did you need to do anything else for the R134a conversion? I've heard it means replacing all the O-rings and putting in a different receiver drier (both of which are wise anyway on an old system with unknown history)
Nice.. I do love SA!
I have some photos and parts list for my HJ60 R134a conversion here:
Gorgeous part of the world. And sure beats trying to drive the 60 down Bell St every day
Appreciate this. Did you replace the pressure switch? If so, what did you use? I haven’t tested mine yet, but the original Toyota part seems to be discontinued and every combination of words I try searching for either shows me oil pressure switches or ones which seem to have a different plug
I’ve heard the same, so I’ll probably just test it as outlined in the FSM
Just trying to get together a comprehensive parts list because I don’t know when the A/C was last functional, so I’m preparing for the worst
Have you stripped your system down yet? A lot of the connections are steel on aluminium and are often seized by galvanic corrosion. So there's a good chance you'll need some new hoses or a new evaporator. Some of the parts are easily recreated by a hose shop, others may be much harder to reproduce and may have to be repaired or adapted. Or are you first just going to flush your system and charge it up, and hope it does not leak?
The switch you are looking for, 88645-30250 should be available from IMPEX. Yes, Amayama state they are 'out of stock'; this just means they don't want to supply a Denso part (Denso parts are not techincally for direct sale on the Japanese market). IMPEX has supplied me with a number of Denso parts (though not the switch in question), and since my first order with IMPEX, I have completely ditched Amayama as a supplier (after years of good experience from their Japan sales arm, though the opposite from their UAE mess of an operation).
I flushed all my AC components out with naptha to remove any mineral oil (e.g. in my new R12 compressor). If I was unsure whether the component had had R134a in it or R12, I flushed with naptha, and isopropyl alcohol or acetone (separately). Naptha gets the mineral oil, alcohol/acteone gets the PAG oil. You'll also need to fit barbed-type R134a adapters to the threadrd R12 fittings. On mine, the high side was a 7/16" thread, and the low side 3/8". Not all the adapter kits you'll find have those thread sizes. Consider also access; I think on a 12H-T the access is great; on my 15B-T the compressor is low down and I needed to use an elbow addapter to give sufficient access for the large R134a fittings.
R134a is a smaller molecule than R12, and runs at a higher pressure. Therefore, every joint needs to be perfect to seal. I will finally charge my system next week and cross my fingers.
Thanks for the tip on Impex - I know the Toyota part number, but couldn’t find it in stock anywhere for a reasonable price. I primarily use Amayama unless they don’t have stock or I need something quickly, but I might start checking Impex in the future
Sorry for hijacking your thread, @Silveredition!
