Factory gm truck rubber motor mounts and make brackets to go from them to the chassis
In the his first postWhere did you source the motor & tranny?
Thank you.![]()
Turn Key Engine Supply | High Performance Crate Engines
Industry leaders in Turn Key crate engines. Complete powertrain solutions delivered ready to run.www.turnkeyenginesupply.com
Anyone got motor mount recommendation other than AA?
Agreed been dealing with AA sense 1996 their r&d department needs to do more r&d instead of taaadaaaYeah, anything other then AA.
What would you recommend then? I've mostly seen AA mounts on the build threads. I see that Mark's has some that seem a little better engineered, but they're similar to AA. Very curious to see what's out there...
I scored mounts from TLC that utilize the GM isolator. The mounts were very reasonably priced. At one time they were developing a kit to adapt a LS into a 60 chasis which included the engine mounts, cross member, etc. Not sure if they are still supporting this project but might be worth contacting them.
-Ed
Nice shop! I did mine on a gravel floor. But at least it was covered.
Thank you!
