5" OME comp kit problems (noises)
San Diego CA
So about 3 months ago I had the OME competition kit installed on my 80. See link below
80 Series Competition Coil Spring Series Kits
Right off the bat I was having problems with a grrrr noise when letting off the gas. It subsided somewhat as the lift settled. I also had the shop have a look at it. They were able to replace the cv joint up front? They replaced it with a new used one and it seemed to quiet down even more. It was almost extinct but now has started to come back. Now I get the noise even when im pressing the gas pedal and when I let off. They are certain that the noise is coming from the front drive shaft, which makes sense. I have read numerous posts about the grrr noise on the board. Man-a-fre suggested replacing the u-joints and other shops suggested a DC drive shaft and said that may work, may not. Im just wondering if anyone else with this kit has had the same issue and was able to resolve it. This kit. Im interested in suggestions on how to address this, I have an appointment at the shop on monday but am hoping to get some feedback from the board, since another 80s owner can often be the best expert. I bought the 4" springs for the rear and used the 5" springs for the front FYI.
On the 5” kit a 4+plus control arm relocting kit is used in conjunction with OME offset caster bushings to realign the control arms, and regain proper front end caster.
To counteract axle offset from lifts higher than 2" the kit is supplied with Australian made front and rear adjustable panhards rods that allow repositioning of the axles and increased flexibility.
4+Plus super HD adjustable rear upper control arms w/spherical ends allow for realignment of rear pinion angle and increased flexibility.
I copied and pasted this from the website, just so you know what has been addressed. If I am nto get a u-joint, what kind and where to get?? hheeeeelllllllp
most folks are going to tell you to get a caster sweep so we know where you sit with caster. Also a front height measurement will help (edge of fender flare to center of hub) Then rick (landtank) can tell you if you will need a DC shaft or not. I would put my money on needing one.
How does the truck drive other than the grrrrr? Does it track straight or does it like to wander?
Oh boy! search for Grrrrrrr or vibrations.
Basically your u-joints are at an unhappy angles. It's possible replacing the u-joints may fix it..."possible"
With the MAF control arm drops and caster bushings, you may be in the perfect spot for a Double cardon driveshaft.
I am sure I have the stock front DS, not a DC. I wasnt sure if the guy knew what he was referring to when he told me he replaced a CV joint, maybe the rear DS? I ordered all new u-joints shortly after posting from MAF so they are on the way. I have been re-reading the "Grrr" threads...exhausting. It seems like its most often u-joints or needing a DC type DS. Im thinking I could order a DC shaft from a local drive shaft shop and save a little $$?
:bang:
This is cutting into my slider and snorkel funds.
Haha, you must have missed the tons of info on lifting an 80 past 2.5" starting to cost moola money.
I wouldn't rule out your rear drive shaft either but find out what the story is on the front first.
Also what are your hub to fender measurements, front and back? Did you just use Man-A-Fre's drop brackets to correct the castor? Maybe you can snap a picture like this to help give us an idea of your u-joint angle.
attachment.php
Thanks, Rick :hillbilly:
Thanks Ben I will take a picture in the morning. I can get those measurements tonight as soon as I find my tape measure. I knew these suckers were not cheap to deck out but I still need to bitch and moan a little;)
No, I did everything the kit has included in it, in the red lettering of orig post.
The measurement is from center of hub to bottom of fender, correct?
They are certain that the noise is coming from the front drive shaft, which makes sense...
A few thoughts...
Have your removed each shaft (individually) and driven the truck to see if there is a difference? I was certain mine was the front drive shaft as well, until I pulled the front shaft and the vibes were still there. Upon closer inspection, the splines on my rear slipyoke were worn and sloppy. I opted for a rear DC shaft rather than a rebuild and the grrr went away.
I still had a little vibration until I put in the adjustable panhards. After realigning the axles horizontally, it drives like it did before the lift.
An final alignment to bring the toe back into spec also helps.
There should be no change in toe after lift. The only adjustment needed is to lengthen the steering link to match the corrected pan hard bar. This can be done by a few trial and errors until the steering wheel is straight.
Agreed. I only mentioned the alignment as good measure following the lift. Toe was mentioned as that's really the only adjustment.
hmm
Thanks Bear and others for the input, it would help if I knew more... I am going to learn more before this is all over, that is for sure.
Bear- what correction should they have done in addition to the correction the kit provides (bushings, drop brackets, plates...etc)?
I have been trying to help the mechanic by forwarding info from mud to him in this process, thanks.
The caster in the kit looks to be at least attempted to be addressed from the description. Why would MAF not warn people that a DC driveshaft would then be needed to solve probable driveline vibes resulting in that amount of lift and corrected caster?
On edit: I saw now he did NOT use the MAF drop brackets. Wow, what a mess.
Wait a minute. The 4+ Man-A-Fre is the drop brackets up front. The 5" is the drop brackets WITH OME bushings. So ZPDFJ, you should have the drop brackets and probably be ok with castor if this is the case. I woud bet that with that correction you will need a DC drive shaft to solve you problems.
I think Man-a-fre is slighty short sighted on the lifts they sell so I'm not surprised about the absence of any note for drive shafts.
That's what I like about Slee on 4"+ lifts--everything is addressed that could be(come) an issue,whether needed or not, for the firrst-timer, not the rest of us who piece everything together seperately, or when needed.
I also have an OME 4" Comp lift kit and with the provided drop brackets and my caster was at .8*... So I added Slee's blue bushings with the drop brackets to get me just shy of 4*.. I definately feel like I got more than 4" of lift..Parked next to a Slee 6" mine looks like it sits a bit higher.. The last time I measured from hub to flare I was 24.5" front 25.5" rear. Seems like a few more inches than advertised??
Sorry for the Hijack:
I also have a slight harmonic grrrr only at hwy speeds I'm not convinced it's the driveshaft because I have a 60 series split case/700r4 with the front shaft disengaged in 2H..I have my upper adjustable control arms as short as they will go and have the rear pinion angle really close to parallel.. My rear shaft was balanced, resized and rebuilt when I did the diesel swap so it should be solid...Any chance a harmonic grrrrr felt in the seat at hwy speeds could be a bent rim or defective tire???
woah tak it eeesy (nacho libre voice) Look again at the first section of the red text Bikeman, drop brackets are on there....
You are correct. Thats why i posted the link and red text excerpt so you guys would know what im working with. But yeah bear Slee agrees with you about the last part. I should have bought the Slee kit, damn. I am gonna try the u-joints then the DC DS if that does not resolve the issue I guess.
