Also what are your hub to fender measurements, front and back? Did you just use Man-A-Fre's drop brackets to correct the castor? Maybe you can snap a picture like this to help give us an idea of your u-joint angle.
Anything I am going to break by waiting and letting the shaft vibrate for a few months?
Other than beating the everloving bejesus out of the t-case output and pinion bearings, as well as the u-joints (which may not matter to you if you're replacing the driveshaft anyway)- on second thought, why not just pull the driveshaft now?
-Spike
The play in the slip yoke was at the rear? That is usually the case.
I think the shaft guy is thinking that the slip yoke is over extended. Sometimes, not on Toyota's, there will be more play in a slip yok as it extends due to less engagment.
I must add for information purposes that not all lfts over 3 inches causes a need for a DC shaft. Jfz80's rig has the slee 4inch front springs with the OME yellow bushings in. Not sure what his caster is, but he has no grrrr and he's running the stock shaft with old ujoints. I have driven his truck and it drives great. I want him to get a caster sweep so we know exactly where he sits.
My other beef is that ANY lift that raises the front over 23.5" makes "L" shocks a waste of time. They are not even long enough to balance the wheel travel. Other than that it's just buyer preference on the use of drop brackets. This just my $.02
Unfortunately, there aren't any lifts - from anyone - that high that don't use L shocks -
I don't know.....I think they are alright. It might be only me though![]()
