the mixed bolts are kind of normal. when you got the water out, did you seperate it from the oil at all? if so, sounds gross but dip your finger in the water and taste it. maybe it's just moisture from sitting and not necessarily antifreeze. with a crack in the pan and a poor seal anything is possible (that said, i doubt it, but who knows)Pulled the oil pan today and notice some water in the bottom of the pan...wasn't a lot but it's there. Cleaned the pan good and noticed a crack on the edge of the front curve. Hopefully it can be welded. The PO that put the seal on did a half ass job so no wonder it's leaking.
Friend said I should just put on a new seal and drive it for a while then change the oil and see what it looks like. If it has water in it I guess I could change the head gasket or put in some block sealer. Eventually I want to do a sbc swap so it's no point in dropping a ton of money into an upper engine rebuild. Not sure yet what I should do. I haven't noticed any water dripping out of the exhaust though.
Can anyone recommend a good block sealer if I decide to go this route? I saw some stuff at Orielys that was $70bucks and some for $10.
Also are the 22 bolts that hold on the oil pan the same size? I noticed a few of mine have different heads on them. Some have phillips screw with bolt heads that look factory and some don't.
nuclearlemon said:if so, sounds gross but dip your finger in the water and taste it. maybe it's just moisture from sitting and not necessarily antifreeze.
As long as you don't put those rims and tires on your 55, everything will be cool!
The needle was also cleverly taped on the center. Would of never known if I didn't open it.
failed.Going to work on the ujoints tomorrow. The rear driveshaft has a lot of play in it. Front is tight. Any tips?
jdfording said:Pulled the xfer case and tranny. I'm glad I did, the rear main seal was leaking. The PO forgot to pull off the old spring that rides in the seal so there were 2 springs in the bearing cap. The flywheel needs resurfaced as well.
Going to replace all the seals and gaskets on the tranny and xfer case. Waiting on parts for now.
Questions:
If I do will I need to support the engine or will the front mounts hold it in place? I would like to pull the bellhousing anyway just to clean all the crap off it.
Can I use gasket maker to attach the rear dif cover or do I need the cork gasket?
I hate waiting on parts...
You must support the rear of the engine if you take off the bh. The front mounts will snap if you don't!
I've used silicone when a gasket wasn't available, put prefer a nice new cork gasket if given the choice.
