Hey so I need some help on diagnosing this thing. The guys here seem to be the most knowledgeable about most things so I thought I'd bounce it off you guys.
I ran out of gas last week.
Put gas in ran fine for about 3-4days then just started getting sluggish, loss power, some backfiring when you try to jump on it. so I started with the simple and cheap tricks.
1. ran about 1/4 tank through with injector cleaner.
2. replaced fuel filter
3. tested fuel pressure - steady at 55 at idle, goes up a little with initial pedal, steady then at 55 again, drops with release of pedal, then steady at 55 again. never drops below 50
4. I have tried 1/2 can seafoam and let it set for about 20 minutes. started it up and idled it up to around 2500 to blow it out. still runs like crap.
5. trying seafoam again and I am letting it set overnight now.
My codes are:
P0300 misfire
P0174 lean fuel
then a bunch of other non coed stuff that also makes sense since it is running rough.
but any help would be great.
thanks!
My codes are:
P0300 misfire
P0174 lean fuel
thanks!
