5.3L Temptation
Jackson, WY
So I inherited my 86 FJ60 from a family member last fall and have started dumping money into it just as many others have done. These things are expensive, but so are most other hobbies!!
I recently purchased a 5.3L out of a 2004 GMC Sierra and pulled the 2f today. I have read most all of the posts on this forum and felt that I would post another build as I will probably have questions as i get into it more.
Here are a few pics from what I've done so far, removed the dog house, engine tranny. Time to start cleaning.
don't stop now, the fun has just started...
Get a ls1 Camero oil pan and clearance the tranny pan or your drive shaft will hit both and the front diff will hit the oil pan .. Ask me how I know ... You'll love the power
Thanks for the insight, any suggestions where to get the LS1 pan?
run a mechanical fan, the contour fans work well, but the mechanical fan cools better. I was able to adaprt the stock shroud to work with more sheet metal and cutting and welding. Stock new rad has worked well for me too.
TH eoil pan from the camaro works but you may have to cut it and weld it also. I welded Satchel's pan on here. I am running the stock 5.3 truck pan and had to cut it and weld it.
Oil press sensor from the 2f fits in the oil cooler port above the filter on the 5.3 you'll ahve to drill it out and tap it.
Water temp sensor fits in the right rear portion of the head on the 5.3. remove the plug there and drill it and tap it to fit the stock sender before installing the motor.
Small autometer tach fits the stock opening with clever mounting. you may have to make a "pull up circuit" to make it work.
Had bad luck with Fuel Injection Specialties doing me harness and computer... I ended up using Wait4Me Performance you could do all the wiring yourself.
Inline pumps work and I ran one for a while but ended up going to an in tank pump. search "in tank pump"
DL angles will need to be resolved after you get the motor mounted with axle shims.
stock pan clearance on mine the motor is too low and hits the top of the diff and the yoke clears by a 1/8 in:mad: ... dont have any pics but even a non CV shaft hit the rear corner of the tranny pan :bang:
I like my Taurus fan set up one comes on with the temp and both with the A/C even in traffic over 100deg( A/C freezin ya out) in south Texas stock NEW Fj60 rad and she stays cool I wish the guy that did mine didnt move the in let co it was still a cross flow but no problems yet.... the stock Tahuo P/U upper hose will work with the stock radiator ports
you can see the top ports was move to the passanger side .. oh and these hoses look cool but ALWAYS leak dont use em
plenty of room for a stock fan if needed .. I just wish the motor was 1 1/2 up
gmpartsdirect.com also has good price on the oil pan.
Find the sweet spot on that engine and you will not have any DS clearance issues.
I would set that engine as high as possible... if yah got a welder and a mitter saw you can make your own mounts... I just replaced my motor mounts pads and used the transadapt buisquit pads. The downey pads were pretty much shot....
Nice engine btw....
Post questions and pics in here... this website is awesome as a resource...and peeps willing to lend a hand.
I second not using Fuel Injections Specialties....... they do yucky work...
MY harness is a Tech Rod harness well marked easy to follow...so I could find jaskass misswireing ... and the techs are REALY helpful... called em a bunch to trace my wiring wows all due to improper conection by the installer(not me)
TechRods Home
also DONT use a MSD 7222 fuel pump I'm about to replace my 2nd pump in 10K mile:mad: very load too... they are warranting them but it still sucks
Camaro Camaro Engine Oil Pan Kit, Aluminum, For LS1, LS2 & LS6 Engines, 1967-1981 - Rick's Camaro Parts
best deal I could find on the oil pan kit... as for the tranny pan I plan to pull it of and clearance the side to clear better .... also is you have a CV front shaft it wont clear the trans so move it to the rear and have the rear shortend to fit .... works as long as the clearance the pan's and route the exhaust right:mad::lol:
Sorry for the hijack but Is pan clearance an issue with SOA rigs?
Looks like a nice set up!
Clint
Clint
on mine it still may be but if the motor is set up right no.... even SUA it can clear but needs more work
I decided to go with wait4meperformance for my harness re-wire and computer.
I've got a welder, does anyone have any good pics of the fab work done on their oil pans?
are you running the auto or keeping the manual? what are you using for adaptors?
running the 4l60E with AA adaptor
Here's some of the work completed today
The last one is of where I think the temp sending unit goes, correct?
yeah...i'm pretty sure the hole in the cylinder head there is for the temp sender. I'm sure someone of the other folks with this engine will chime in. is there not one on the other side cylinder head... I thought most othe sensors were on the "drivers" side?
The factory one is on the driver side but there is not a port to put the toyota one on the driver side, the only one i see is on the passenger side.
..I've got a welder, does anyone have any good pics of the fab work done on their oil pans?
unless you can tig alum you cant its cast alum :( tranny pans steel its easy I"ll post pics when I do it ... maybe I'll get off my ass and do it Tomarrow:hillbilly:
z06
Can you use a dry sump system from a z06 engine into a 5.3l?that would be awesome if it would work.
