5.3L Temptation
looking good! I must say though, standard pull up circuits scare me. Doing the resistor trick works, for a time being. There has been a lot of debate on this in other forums. What I've learned: the gen 3 PCM contains an internal 'pull up circuit' that can be adjusted to the proper voltage required. This can easily be adjusted in HPTuners, or so I've read. The pull up circuit causes greater current to flow through the circuit in the PCM, which can potentially cause it to burn up. It won't happen right away, it may never happen, but it is a possibility. Whats the easy remedy? Create a circuit that acts as a buffer between the tach signal from the PCM and the tach. It utilizes your conventional pull up circuit, but it protects the PCM from any added current. Here is a schematic of the circuit. schematic of the circuit. It cost me less the $5 to build, and has worked great so far.
I think it would be easier to just put a diode in the tach output of the pcm if you are worried about it. I'm curious if there has been anyone that has actually burned up their pcm from doing this. I know there is some debate about whether any of the pull up voltage is making its way back to the pcm, but I haven't seen anyone with an issue I don't think and I know quite a few people are using this same setup.
After getting the motor installed, it's taken some time to figure out the wiring. I'm starting to understand how relay's work. Also, cracked the fuel rail during the install and when going to start it a couple weeks ago, sprayed fuel all over the place. Two weeks of waiting on GM and finally got the new part in last week, and got it started this last weekend. Here are a few pics of the progress.
Today, it's off for exhaust work!!
It's hard to tell from your pictures, but it looks like your oil pan may be close to hitting your axle housing. I assume that a side angle would show that it's not close, but you will certainly want to check your clearance all around the engine and make sure nothing hits as your springs compress such as the oil level sensor Marco mentioned. My feeling is that you are good being that we set it up with the same dimensions as mine and you have more lift than I do, but you are also using a different oil pan, so just make sure and double check those clearances. Bump stop spacers would help to make sure nothing hits as well.
Looking real good, glad to hear you got it started up! Hopefully the shafts show up in the next couple of days and you can enjoy your Christmas present.
Found out over the weekend that the oil sensor is going to hit on the flange of my third member. Also, had the exhaust routed wrong so I'm sending it back to the shop this week to have it routed properly. The front DS hits it when flexed. The only codes i'm getting are PO171 and PO174, running to lean on Bank 1 and Bank 4. I've cleaned the MAF and my filter, since i think i over oiled it to start with, any other ideas other than replacing the MAF?
What fuel pressure are you running it at? Should be 58psi. Does it throw the code immediately or does it take a while to throw it?
it's running at 58 PSI. it usually throws it immediately. I went to car quest this morning on my way to the muffler shop and tried a new MAF they actually had in stock. Code went away, drove it for a couple miles and still did't show. Think I got it fixed.
Also, I probably going to have to take the oil level sender out, will that cause any issues? Can i just disconnect it, or do i need to have the computer re-programmed?
Mine doesn't run an oil level sensor, and the last time I was poking around the ECU looking at possible codes I don't think I remember seeing one for it.... try just un plugging it and seeing what happens. I removed mine to make room for the drive shaft and welded up the hole.
If you go to get the pan modified again, make sure that's all that needs to change. see if you can REALLY flex it out so you get it to sit HARD on the bump stops on that right side. Then with it level see if the available up travel will allow it to hit by just measuring the space between the axle and bumps with a tape measure and imagining the axle moving up that much at the pinion.
Also, you'll want to make sure that there is space side to side to account for the axle shifting side to side a bit.
Good news on the MAF sensor, that's awesome :)
Thanks Marco, i'll look into those measurements before i take it back in for mods. Looks like if i can get it straight with the outer edge of their original cut I should be ok, even with the sideways movement of the axle. but i'll double check.
Also, got it back from the muffler shop and the check engine light came on again same codes. Any other ideas how to resolve them?
I had rich codes on mine for a long time until I swapped MAF sensors with Marco and I haven't had issues since. It pretty much has to be not enough fuel going through your injectors or your MAF sensor is acting up or waitformeperformance adjusted something wrong. I would contact Jesse out there and see what he thinks. You had the original MAF sensor from the donor truck though, right? Those things can be a pain. The only cheap fix I can think of is to tighten up all the screws on your intake hose and make sure nothing is loose. Double check for any other vacuum leaks.
more maf sensor info........
if you're using an oild air filter, then make sure you clean your maf at regular intervals. i don't run oiled filters on my conversions because they can/will cause issues with the maf.
to clean the sensor, use a q-tip and denatured alcohol or the specialized maf sensor cleaner available at most auto parts stores. do not use rubbing alcohol; it contains some oil to keep your skin from drying out.
hth
georg @ valley hybrids
If I may....
Going back to the TRANS PAN...
Mine, with a DC shaft, clears at the t case end, but its only about 1/2- 3/8 in away from the trans pan.
Theoretically, it SHOULD not deflect that much, but...it is a little close for comfort.
Kling-on posted a pic of a trans pan with a radius cut away into the side...Was it ever determined that that pan was a SWAP, or a custom fab job?
Are you running into any clearance issues with the trans pan and the shaft?
Build looks GREAT!
here's a pic of the tranny I found on line ... I dont know if this is a swap from somthing else or the best chop and mod I've ever seen
This one....
Id really like to find THIS if I can!
It would give me warm and fuzzies if I could.
Chicago-
I did not modify the transpan, had a new drive shaft built by a shop in Englewood colorado. I think it was bills driveline or something like that. Satchel hooked me up with them and he did a great job. I've got 1/4" of clearance on the side of the shaft to the oil pan. Haven't heard it hit yet, mostly issues with the oil pan. Pulled it last night and dropped it off at a shop today to see if they can get me some more clearance.
Rover- The pump sounds good, i can hear it running when outside the truck at idle. When i first put it in it was pressured to 63PSI so i turned it down to 58PSI. It holds steady at that. I've cleaned the MAF a couple times with the cleaner you mentioned, the code goes away for a couple minutes then comes back on. I'm going to clean my filter next and the MAF again and try that once i get my pan back from the shop.
Thanks for the tips!!
Chicago-
]/QUOTE]
Copy that!
Thanks for the info and sorry to hijack. I was just curious.
