In the strange but true category...
76 Toy, make sure everything is new, tight, or in spec (sounds like you have). Do some searches with "death wobble" here and at Pirates. Some good discussion and might bring up something you have missed.
I have flat steer arms (custom OTT flat arms, OTT relay/tie rod/pitman arm) new bushings, new springs, 4 deg + caster, completely new front end components, knuckles set at 12-14lbs, wheel bearings at upper end of spec, tight steering box, new u-joint in the steering shaft, u-bolts tight at the springs, new TRE's, wheels balanced (35x12.5x15 TXR), tried a variety of toe in measurements, and would still get the DW if I hit a bump at a certain speed, with the right angle. I was into the front end countless times replacing, checking, etc.
Put a damper in the stock location (frame to relay rod) and would still get it if I hit the front left tire on a sharp drop (manhole cover with 2" lip or so) and going about 35-40 mph. Brutal. Into the entire front end and steering countless times again, increasing knuckle pre-load, checking other things.
Ended up having a bracket welded to the spring perch, and went from that to the tie rod. Steering wheel hardly moves when I hit a bump now.
Perhaps there is something not quite perfect in mine that causes it. I could not figure it out though, and ran out of time (had a trip coming up).
Don't know if there is enough room at the rearward spring perch to weld on a bracket. Everything is on the front with my set-up, and it worked out great (cept is it in the front where damage is likely).
Ohhh...this is on a BJ60.
And one last edit...I have heard nothing but good about Luke and his product! Will use his stuff on my BJ74 when/if it gets SOA. Talk to him and see if he has any ideas.
hth's
gb
