4x4 Labs Bumper & Resinator
I just completed the install of my new 4x4 labs rear bumper.
As usual as soon as the rig is drivable again, it's back into service even if every little thing is not buttoned up. (in this case the mud flaps are not back on and the exhaust is still hacked off)
But after one day of driving, I have noticed a "whistle" at certain RPM's that stops when the tranny shifts, and starts again at the same rpm in the next gear.
Could this be due to the resinator being off ? Has this happen to anybody else after a rear "labs" intall ?
Yes, whistle is completely because the resonator is off. I cut mine off before my bumper install...and you get the rpm changing whistle.
I recently swapped the stock huge muffler for a thin tube style muffler and the whistle disappeared.
X2 on what RX7 said.
Also, I never did put my flaps back on, since you lost most of the mounting points when you removed that rear bumper.
Mine always had the whistle, with the resonator off it's louder. When the resonator is cut off the rear mount is lost, the rear pipe shakes around, cracking the muffler, etc, add a mount back there it support it.
I would just pretend its one of these and forget about it........
Great to see the replies (I was afraid this thread would degenerate into . . . a whistle or a whine?
Does it sound like weeee . . .whaaaaa . . . .wheee?
It it more like a hum ?
Any way , you get the idea.
So is the only cure to remount the resinator, or can the tip just be put back on ?
swap out the muffler....
I went for one of those red tube Thrush mufflers for a few reasons.
As Tools said, the rear mount is gone after the resonator leaves, so my big stock can muffler was able to make contact with my rear driveshaft which was an annoying noise.
I could only push the exhaust over so much because of the giant stock muffler, so the cats were rattling against my sliders every now and then.
The much thinner muffler gave me a lot more room to push the exhaust where I needed it and I had the shop add a rear mount to keep it there.
I thought it might be a LOT louder and kind of annoying with the Thrush muffler.....but its not even noticeable at idle, and barely louder at heavy throttle.
The whistle completely disappeared after I swapped the stock muffler out.
I have been thinking of doing a cut & turn on the cat's, maybe an exhaust mod should be my next project.
Any other mufflers folks have used ? (sorry you had to tell me twice CodyRx7)
Flowmaster 50 series 2.5 in center inlet center outlet fits nice and tight by adding a 8-10 inch 2.5 tube in front of the muffler. The Flowmaster gives the 80 a little more power on the lower RPMs and gains clearance. The exhaust is slightly louder but no louder than mud tires.
The whistle is gone with the flowmaster.
x2
the reason toyota shot the exhaust out the back so you don't hear it much w/ stock.
resonator doesnt do jack, been there done that.
I'm going full exhaust replacement- my muffler and pipes are all jacked up by rocks now
x2
Mine is somewhat louder without the resonator, so it does something, just not much.:D
X2, mine is getting a single cat, piped up over the frame and an oval muffler on Tuesday. The stock stuff is beat to snot from rock contact.
Finances finally allow me to get this exhaust work done. Anybody have a P/N for the proper Flowmaster 50 series?
Or if something else fits well, any make & P/N will do.
I noticed no increased noise from the exhaust after removing the resonator.
That's cause you drive like a :princess:. Hit the gas once in a while, you will hear the whistle.:idea:
