47 Gallon Long Ranger Aux Tank installation USA 200 series...
"MAKE SURE THAT THE TOP OF THE TANK IS NOT IN CONTACT WITH ANY AIRCON OR HEATER PIPES. THIS IS IMPORTANT."
:rofl: Yeah, I bet that is important.
Along the line of brainstorming- I found this CNG tank that replaces the spare- Removing the spare tire mounting bracket and relocating the evap canister would allow for a 25 gallon tank. 2 paths converting this tank to a be a petrol transfer tank or undertaking a CNG conversion... (smile)
http://worthingtonindustries.com/ge...a-6bd7898f9617/LPG-ASME-Toroidal.pdf?ext=.pdf
I think that the center is not utilized for fuel storage so again brainstorming and having a little fun it could be converted to an onboard air tank...
Apologize if this was already mentioned, though I don't think it was.
On the clublexus forums, this option from Longranger / ARB was posted by member zink. A 70L aux subtank model supposedly made to fit for models fitted with a charcoal canister, while leaving the spare in place. If this lives up to it's promises, it'd be a perfect option in my mind.
EDIT: It's not clear, but this may or may not be compatible with US spec models. Something about australian models having a charcoal canister in a different position. Also looks like this accessory comes with an add on charcoal canister to accommodate the larger volume of vapor.
70L Auxiliary Fuel Tank – Retains The Spare Tyre | The Long Ranger
Looks like the carbon canister gets relocated somewhere to the side of the chassis?
I took the dive order and received the Tembo / Excel gravity feed auxiliary tank. The tank construction is top notch- there looks to be welded in baffles- The tank installation looks to be straightforward, the complication will be relocating the evap canister. Extending the hoses will be straight forward the wiring harness extension and fab up a bracket will be the most difficult. I am trying source the wiring harness connectors to build an extension cable rather than splicing into the OEM harness. If not I am going to cut the OEM cable (fun). I am most likely 10 days to 2 weeks from taking this on.
^Awesome. Thanks for being a pioneer.
If someone can identify a good relocation spot for the evap canister, that'll really be the ticket. I wonder where the OP (@dtt255) put his?
View attachment 1432630 View attachment 1432628 View attachment 1432629 View attachment 1432631
Is everything included (wiring, extenders and connectors ect..)? Just not pictured?
This is a fantastic idea. Thank you. I hope is not going to be too difficult to turn it into a regular gas tank. I been looking for six months
Thank you
All the plumbing is included for connecting the tank. There is no transfer pump or fuel float/fuel guage as the tank is gravity feeds the main. The only wiring required is extending the EVAP and maybe the vapor filter harness- then some hoses and fittings. Still thinking through the relocation approach.
Forrest did you ever get your Tembo setup installed and working......what's the latest???
