bustanutley said:
...my sm420 broke all my motor mounts and it is 40lbs lighter and 2" shorter. Engine was bouncing all over the place, it is solid now.
If your engine was "bouncing all over the place", you had other issues beyond a 420 being mated to a three speed flywheel housing.....
How did the transmission destroy the engine mounts, from the additional torque that can be applied to things? I could see if they were in poor condition from the get-go, and added the torque from the 420 to something that was marginal at best in a stock application, that it would be easier to tear up engine mounts, but I still do not see how this can cause a flywheel housing to fail. I have ran my 420 and three-speed case hanging off the back of my three-speed F engine flywheel housing since 1993, and beat the living s*** out of my truck, and not had a single issue with the flywheel housing. When I installed my Atlas last spring, I made a cross member that attaches to the Novak adapter between the 420 and the Atlas, but that was for obvious reasons.
There are many trucks around here that are not using a cross member/additional support and using a 465 transmission on the three-speed F engine flywheel housing, without any issues.
I have seen broken flywheel housings, from people forcing a transmission into a clutch without having things lined up properly, and have seen Chevy and Toyota flywheel housings fail from an impact to the drive train off road, but I have not seen a Land Cruiser flywheel housing fail because of the added weight of a 465 and a stock case.
Now, if I were installing an Orion on the back of a 420 or 465, I would then want to install some form of additional support, but that is because of the extra 90-some pounds that an Orion weighs in at, but I feel that a stock four-speed flywheel housing is up to the task of a H41 or H42/Orion combo, unless you are going to be flogging it.
Unless you are planning on your truck seeing a few feet of air regularly, I would not worry about it.
Did you get those drive shafts installed yet???!!!
-Steve
