I'm running a SBC 400 with the stock tranny. I love the set-up personally, pretty basic engine to run/ fix/ parts/ etc. I had a Farey Overdrive prior to the conversion so that's the main reason on tranny choice, but I feel it's a good one since I've had NO overheating problems (even w/ the a/c) so I'm happy with the setup (So. Oregon summers break 100 so it's been tested). I've known a couple of guys around here with brand new crate sbc 350's and auto trannys and they have heating problems with their setups, they don't have a/c installed and run pusher fans. I did have mine re-built and put in an RV cam, but other than that, pretty much stock and gnarly torque.
From what I've known and seen, pretty much runs same parts as the 350's. I think it runs an external harmonic balancer if my memory is correct. Super easy conversion really, I went with Mark's Adapter and everything was pretty smooth and straight forward, even the engine location to the radiator came out sweet and set up right. Like I said, pretty easy conversion. I did eventually have to have my rear drive shaft shortened (like 1/3", driveshaft guy wasn't too happy). Here's a tip after the Marks' conversion, if after an engine conversion you find yourself constantly tightening your rear driveshaft bolts, try pulling the shaft, it probably won't drop because it's squished in! That was our fault though, I should have thought about the drive line when we were setting up the way the engine sits. Either way, sounds like for that price you can't pass up that 400.
