40 Wiring Problem
Oklahoma
Hello everyone. I have a 1975 fj40 that I am currently restoring. It has a 350 conversion that was done by a previous owner. As a part of the restore, I decided to rewire it to remove all of the extra wiring left over after the conversion. I have rewired a few friends jeeps before so I considered myself to be fairly compitent. I have a very simple problem that I can't seem to figure out. I can't get power to my entire system. I do have power at the starter wire in the ignition switch, but I can't get anything out of the switch. I have been testing at the switch, so any bad wiring isn't an issue. I normally would assume my ignition switch to be bad, but the car has driven and started every time since I bought it in August. Is there someting that I am overlooking?
It goes through the voltage regulator before it gets to the switch. Maybe with the 350 it was switched to a solid state regulator. I would make sure you have voltage at the regulator.
Have you verified you have power at the fuse block? (First step yes - go to switch, no- go back towards battery)
Have you taken the steering column plastic cover off and verified voltage at the switch?
Do you have power t your headlights, these come on without the switch?
I think the guy before me removed the voltage regulator. I don't have any power at the fuse box because my new fuse box is powered by the wires that leave the ignition switch so I don't have lights or anything. I do have power at the ignition switch. I am checking for power at the contact solders on the switch. There are also two wires coming out of my steering column that are not connected. I assumed them to be to the horn. They are on a two wire connector. One is green and white, the other is black. My setup is battery-starter-ignition switch-fuse box-components. Am I thinking of that wrong? I have power in at the switch but nothing out. Do I am still using the factoy connectors so i'm wondering if I need to install a jumper somewhere. My fuse box is not connected directly to the battery, but through the starter, the power to the switch is hot at all times.
That doesn't make sense to me, but PO's have been known to do worse. The fuse box should always have a hot input for the items that require power without the ignition. Typically, thats the Headlights, brake lights, cig lighter. In addition, if you have a newer radio (non push butoon) you will need an always hot wire to store the setup (Radio pre-sets, clk etc) and another wire through the ignition to power the radio on.
I built my wiring harness by looking at the wiring diagram, so i guess I just assumed that by supplying power to the hot wire in the switch there would be a corresponding hot wire out of the switch before the key was turned. I also assumed that as the key was turned to different positions, one of the other wires would become hot, which would power a different set of accessories. My wiring harness is build in three different sections, always hot, acc, and on. If one of the wires out of the switch does not give me a hot lead to that portion of my fuse box, I agree that I will need to power it directly from the battery, but I still would not have power to the rest of my components.
Any chance you have the HOT wire from the starter swapped with the START wire? That would give you power to everything only when you tried to start it. I agree that you need a supply to the fuse box from the battery.
Dave
All the power to the chassis comes in through the amp meter (not voltage regulator) on the big white wire with a blue stripe. At the meter it branches in two with one branch going to the ignition switch and the other going to the fuse block to power the headlights, tail lights, etc. If you have some power at the ignition switch, but none at the fuse block, then it sounds like the PO has customized your wiring, bypassing the amp meter. Get under the dash and trace the white wire with the blue stripe and you will ultimately find the problem.
Not trying to be a dick, but are you sure that this is correct? I do not remember a white, or white with a blue stripe wire routing directly to the ignition switch on any of my Land Cruisers( 1965-1985 years )...
Thought the only things connected to the white, or white/blue wire would be the alt, ammeter, + side of fuse block, and the starter...
Alt to + side of ammeter, - side of ammeter wire splits to fuse block, and back to solenoid stud on starter on earlier trucks w/o fuseablelink, and through the fuseable link on newer ones...
I could be all wet though too...I am certian that you will let me know ;)
-Steve
For sure it has been a while since I peeked under my dash, but my recollection is the main feed circuit is white from the battery to the amp meter and white with a blue stripe from the alternator to the amp meter and to the fuse block. Whether the branch that feeds the ignition key is the same color I do not remember, but for sure the switch gets power from this same feed line that connects to the white/blue side of the amp meter. The switch feed wire might physically connect at the fuse block as well. The schematics I have show this wire as being white with blue stripe.
Thought that the Ign switch hot wire was black with a red stripe...it must tie into the white wire then...
Black with a white strip is start, Black with a yellow is igniton, black with a red is power into the switch, and white with a red stripe is acc...
I think....
:beer:
Just went through this this weekend with my 45, donor vehicle a '72 FJ40. Big white wire from battery hot post on the starter to the ammeter. White with Lavender (blue) stripe to the alternator "B" terminal. 1st Branch off the WL past the Ammeter is either W (72) or WL (earlier) or W (earlier yet). 2nd branch off of the WL past the Ammeter is BR to the ignition switch. In the '72, there was also a heavy R that took off along with the W or WL that went to the fuse box, but I don't know where that went to.
