40 trans install question
Plant City, Florida
can I get this in from the top? Advice please
I’d put it on a skid or tans jack, slide it in from underneath then grab it by the crane and lift up. Or if you have a trans jack use that, and the crane with a load leveler to get the angles right.
Nothing about that job is a fun experience lol.
You can fight with it for a few hours...
OR
You can put it on the floor, remove the tcase lever and lift it up and wrestle with it that way.
Find a couple 12mm X 1.25 bolts, cut the heads off and make two alignment dowels for lining the trans up with the flywheel housing.
You will thank me later.
:beer:
Using the load leveler was key to making it easier. I have one but like a dumb ass didn’t think about using it until Rick suggested it.
Max 3 hours? I’m impressed. Way to go.
About a hour of effort, and that was with having to pull it back out when the throw-out bearing came loose. I feel we got lucky but the key of course is getting it lined up and level and I attribute that to the load leveler.
OR
:beer:
As a 17 year old trying to get my tranny/transfer back in, 32 years ago....I kid you not, it took me weeks of trying. Not that I had the correct hoist/jack/leveler....just a rope and some chains holding it all up from the beams above. Didn't have the money or know-how for anything else. But I must have worked on it a every day, another try at lining it all up. I did have the alignment tool but holy crap I put a lot of sweat equity in that job. Deathly afraid to this day of pulling the tranny....
How easily does it fit underneath the truck? Did you have to jack it up much? Tire size?
after 40 or 50 they are not so bad i modified my tranny jack and they usually slide right in
@shelfboy1 not to derail this thread but what does that modified tranny jack look like? Would be good tech if I ever have to pull it again!
If you can do it with an engine hoist and a load leveler (and you have the tunnel cover off) I would not mess with a tranny jack (based on my vast experience of....one).
tires 32s and no problem sliding it under using a creeper that sit a couple inches off the deck
...That's good to know. I have 31s so I should be close enough. You didn't have to remove the tranny shifter?
Yes, I did need to remove both shift levers. my 3/76 has a welded frame cross bar with the t-case bend in it. I had shift the tranny sideways and use every millimeter of that bend AND drop the back of the T-case down a little to tip the front shaft up and into the bell housing. I did it with the e-brake drum installed already. That's another area that the load-leveler was helpful.
