40 trans install question
...That's good to know. I have 31s so I should be close enough. You didn't have to remove the tranny shifter?
The transmission shifter almost definitely has to come out. You need to remove it to remove the transmission hump so it will be off either way. It takes literally 5 minutes - you’ll spend more time fighting it if you leave it attached. I found having the transfercase linkage hanging loose, off the pivot, prevents it from hanging up on the edges of the tub or on the transmission tunnel if you’re installit from underneath.
If using a tranny jack from underneath, the tranny hump, fuel tank and seats do not need removed. Remove the shifters, then support back of engine oil pan w/ toyota bottle jack. Remove bellhousing engine mounts. Lower back of engine an inch or two, so shift tower is beneath floor. Unbolt tranny, slide off with tranny jack.
I am able to get my transmission hump off without removing the tranny shifter. It's tight but I can do it and have done it many times. I can't tell you how come I am able but my rig is tweaked a bit body and frame and that may somehow provide the extra leeway to make this possible. On the flip side, I could not remove my valve lifter rod closest to the cowl with the head still on. It bumped up against the lip of the cowl. I was told that was "unusual" as well.
