40 series general tech and classifieds
View attachment 1344231 2F was bored .020 over and it has an H55F 5-Speed. With the 4.56s and the 35s it is a great dual-purpose rig. Front/rear ARBs, full cage, OEM bows and soft top, OEM soft doors, hard top with ambulance doors and rear hatch with proper header to run hardtop with tailgate.
Drool
Jax and I pulled her out for a long idle, short drive, full wipe-down and got all 5 KM2s to 37 PSI
I DD it a little last fall...had a weird braking episode. Everything is new but the booster...so I'm going to get one of Racer's and call it good.
I have a "company" car right now...and our weekends are usually full of other stuff. No good excuses but haven't had the discression for a $275 part (sad) or the time as my aging fleet: 99 100 w/ 205K, 98 4Runner w/ 290K and 1986 mini w/ 137K keep sneaky taking vehicle funds and time.
Cool rig, man.
Holy snikes that is fine
Has anyone had any experience with a sticking brake caliper? Right front on the 40 is still sticking after new soft lines and a thorough bleeding. About to start searching but thought that I'd hit yall up as well.
It is fine for a bit when you drive it but gets tight as you go and then starts dragging noticeably. I can open the bleeder and fluid comes out and it works fine for a while again. Bad caliper? Residual valve (although that would seem to affect both sides?)
Only thing I can think of is that the square cut seal on one of the pistons could be going out; that would cause the piston to not fully spring back after braking.
If that's all there is, you can buy a new set of seals from RockAuto for next to nothing.
My second guess would be the master cylinder, but considering it's only dragging in one side, I'm going with the former.
Can you pull the wheel off and look and see which pistons are dragging?
And although the brake calipers were in horrible shape they didn't fix the problem. If anything it is worse now. Will try to shorten the push rod and see what that does for it.
I took a look at this one today. It needs a good amount of body work in the back but could be a good project if you are looking for one. Hard to get a running driving 40 for what he wants. Chris was a super nice guy and may be coming to the next meeting. Let me know if you want a few of my pics or info if further away and interested.
1969 Toyota FJ40 Land Cruiser
Well after thinking that I was chasing the right way I think it is something other than the push rod length. I backed off and it seemed to help a bit but not completely so I went a little shorter twice more but it never helped. Maybe a residual valve issue? I think that both sides are really sticking but when I release the pressure on the right side it releases the pressure on the other side as well. Maybe a complete rebuild of the master is in order. There was a little dirty brake fluid in between the booster and the master.
Sorry, I'm a little slow on the uptake tonight. If this is on your newly purchased 40 with factory disc up front there should be no residual valve on the front circuit. Disc don't use them. Could be a bad caliper (you changed them already), hose, master, or relay rod length issue.
