40 inch throttle cable
Kamloops
Hi there
I have a 1976 FJ 45 that I have installed a 13BT in
drove it last summer and it worked nice
this winter I plumbed up a air to air
and changed the way the throttle cable worked on the original 13BT setup
is there a 40 series throttle cable from the pedal to the engine that is about 40 inches long?
I got one out of a mini truck that is the right length but mounts quite a bit different
the best way would be if there was a model/ engine arrangement with a 40 inch cable in a 40 series
Thanks
I make a 42" long cable for Chevota engine conversion where the throttle body is at the front of the engine, it is trimmable, can be made shorter, It is an upgrade over the factory cables, It works with the stock Landcruiser pedal, will cost you 39.95 plus postage, I can send a paypal invoice, lemme know.
The end that goes to your pedal has a brass bar that swivels, unlike the lead slug on the end of a factory cable. The end that goes to the carb is removable so that you can shorten the cable if you wish, then install the end piece. The end piece is threaded, but smaller than the factory cable, so you would have to use washers with my end piece.
