40 front end "Thunk"
Colorado Springs
Team, I'd love you opinion on something. My '73 FJ40 has a "thunk" coming from the front right wheel. The noise matches the tire's RPM, occurs when hubs are locked and unlocked, and it's more consistent with a slight right turn. I've jacked up the front end and spun the wheels but cannot reproduce the thunk. All steering and suspension components are tight. I have disk brakes and all the components there are tight.
My next step is to pull apart the hub but I'd like some thoughts on what it could be first.
Thanks!
Based on your description it's most likely one of the following:
1. Worn Steering Center arm (clunk while turning steering wheel)
2. or, Bad tie rod ends (TREs)
Here's a link to related threads: https://forum.ih8mud.com/search/4816886/?q=Center+steering+arm&o=relevance
Have a helper turn the steering wheel while you listen and touch the steering center arm you'll be able to feel the clunk. Once you've verified the clunk is coming from the center arm you will need to rebuild it, there are kits available.
This is the center arm
attachment.php
Rebuild kit
Tie rod ends
how well is your knuckle greased ?
I just pulled the right knuckle apart. No issues from the birfields out: well greased, tight wheel bearings and no play in the birfield itself. I checked the tie rod ends and they are tight. I tightened the center arm bolts a quarter turn - I'll see if that has any effect. Next step is to have someone watch while I turn the wheels and see if anything is binding.
I can't imagine anything is wrong with the front diff. With my wheels unlocked and in 2 wheel drive, there's nothing turning in there. Right?
Thanks for the responses! Back to the garage...
is the caliper properly seated ?
brake pads worn through ?
Weird. After putting the knuckle back together and buttoning everything up, the clunk is now gone. Was something loose? Stuck hubs? Voodoo magic? Who knows - I'm just glad it's working again.
Thanks for the assist!
