Trying to get brakes working on a ‘71. 40. Replaced master cylinder, front and rear cylinders. Bench bled new master. Then tried bleeding rear cylinder first, then fronts. Fronts “work” OK, wheeels won’t turn when peddle pushed, nothing in rear, few bubbles. Peddle is soft for first three pushes, then gets firm, little bubbly fluid out left rear. Went to first fitting on firewall where rear lines tie into go to back. Re bleed master from there, seemed to be OK, consistent bubble free fluid. Next went to fitting on rear axel. Same symptoms as rear bleed valves, little bubbly fluid. The replaced hose from line to rear axel. Tried bleeeding from fitting at hose connection. There back to three soft pushes, then short firm peddle resistance. Little bubbly fluid there.
Welcome to ideas/ suggestions. Several months of on and off. Two bottles, 64 oz DOT 3, probably 1000 or more peddle pushes. Same results in rear. Could new Master be bad?
