- Thread starter
- #21
Thanks so much... this is what I will try first.... I will try this first...
the other day when i took my top off i discovered why mine was not working properly. the plug on the drivers rear behind the plastic, was all shot to s***You may want to check if you have a blown fuse..... Stranger things have happened....If you have power and the relays are not clicking, then it almost has to be a bad switch somewhere. The motor is powered right out of the relays, but the switches have to tell the relays that everything's ok before they will run the motor.
THe dash light is powered by the "engine" fuse, and the window by the 20amp "Power window" fuse.... I have to go to work now!![]()
maybe I had more to drink than I though... thanks!!! I will check this firstI will try this tonight..... I have tried to close this thing again and again and it seems closed... anyone have a pic of what the "closed" sensors look like on the tail gate?
