4 inch lift
What exactly is required for a 4 inch lift. I know break lines will be in the works but as for as control arms and steering dampener, what needs to be replaced?
Requirements will vary from truck to truck.
Panhards are not "required" IMO and a front driveshaft may or may not be depending on the amount of caster correction you decide to add.
You will need to lower the front swaybar as it will make contact with the front driveshaft when the front axle droops.
You will need to change to longer brake lines for the axle drops. There are OEM Toyota alternatives.
The steering damper is not "required", but it is a good idea to change it out as I assume you'll be stepping up to 35" tires or so.
The LSPV for the rear brakes will need to be addressed in one way or another to get the proper brake bias back after the lift.
Depending on vibrations you may want rear adjustable control arms
Just put 5" front and 4" rear OME competition springs on my 91. Slee caster correction plates up front, new shocks (pro-comp es9000), front bump stop extensions and brake line extensions. Goes down the road great, flexes like crazy.
