4.88 feels same as stock
Margate, Florida.
Good day guys,
I am the owner of a 96 FZJ80 that I have never seen since I bought it while deployed to Africa. I am running 315's KM2's and decided to throw 4.88 gears to get better performance and gas milage. Bought the Nitros' and Had a 4x4 shop do the install....
I did a full tune up on the truck before this upgrade and my friend says it performs the same as before, including fuel filter...... Gears were done and when he picked up the TLC he says he does not feel any difference than before, pretty much it feels like the 4.11 are still there.
Anyone with this issue....... Even if a tune up hadn't been done should the TLC ride better? My friend also says there a weird noise coming from the differencials....... In reality I could not tell you 'cause I have not driven the truck but I should in a couple of days since I am on my way home, but it sucks to spend money on a job like that not to gain anything but noise.
Any sugestions? Please help!
Thanks
ok, your tire is 315mm's wide... how tall is it again? and in SAE...
count the revolutions on the wheels and prop shaft...
what it means is that the drive shaft will turn 4.88 times to every one revolution from the wheels. This may be hard to eyeball on the truck though. but if the drive shaft only turns a hair over 4 then you have 4.10's if it is almost 5 turns then it is 4.88's.
So remove one drive shaft and jack up the other side (make sure the wheels on the one side are secure) then mark on the wheel and the drive shaft and slowly turn the wheel while someone watches the shaft.
It's easier if you just lift one tire off the ground when doing the gear ratio check. Make sure the axle isn't locked at the time and have the tranny and t-case in neutral. Because of the open diff and you turning only one wheel the count doubles. So now it's 8 turns of the tire to 1 turn of the shaft for 4.10 and 10 turns of the tire to 1 turn of the shaft for 4.88.
Thanks a lot guys.... Appreciated..... Now, lets say I do have the 4.88...... Why would it feel like it had 4.11's?
I will not know since I never drove the TLC before the upgrade was done, or with the original tire size.
What could be causing this if the 4.88 are in?
Thanks again!
What elevation are you driving in? I'm at sea level and the switch between the two didn't seem like much until I was towing with the truck in the mountains. If you have 4.88s in there then you definitely would have gained some mechanical advantage but it might not be enough to realize.
The TLC is in South Florida, Ft Lauderdale to be exact. That's sea level elevation.
But wouldnt it feel different? My friend says he feels it the same as before......
Since your friend is not familiar with the cruiser, is it possible he just is unaware of what difference a gear install would make? Did he compare rpm's @ 65mph before and after? Hope it is that simple. gluck.
Here is Skillets reaction when he got his rig back from installing 4:88's
https://forum.ih8mud.com/80-series-tech/219599-got-back.html
Lot of chat but in a nut shell, he is very happy.
Thanks man.
I can see he's happy, but it does not cover performance on highway.
Also what could the noise be? I got the Nitro's, and by reading here in IH8MUD those are supposed to be quiet in comparison to other gears, and my friend says its louder than before.......
:bang::bang::bang:
Thanks!
Let me first say that I do not own a running 80 series. I do own several FJ Land Cruisers. I have rigs with 3:73's, 4:11"s and 4:88's. I do not know what peoples idea of quite is.
From my personal experience, you will not notice a big difference running the same size tire on an 80 series going to 4:88's on flat ground, like Florida.
You will notice a difference in the performance of the vehicle when driving through the rolling hills and mountains. Basically the performance is that you still have power and are no longer over in the slow lane feeling good about yourself because you are passing the semi trucks who have their 4 way flashers on.
You may notice taking off from a stop light will be a bit quicker.
As far as the growling noise. Stop driving it immediately and drain your diffs to see if any metal is coming out.
You are going on the impression of your friend to establish a problem.
The 80 is heavy and its engine is underpowered and inefficient - I would agree that it doesn't feel night and day when you regear, although my experience is at high altitude where it was a dog on 33's, a dog on 35's, a dog on 35's and 5.29's, and a dog on 37's and 5.29's. Gears cannot fix a lack of power and I bet if I had put my wife in the rig on 4.10's and then regeared and not told her she never would have noticed because she doesn't try to drive it fast anyway.
Fixing the speedo with the Yellow Box on my rig probably made as much feel difference initially has the gears because it fixed the shift points, which in my case remained way off since I went 5.29's.
Where I notice the huge difference is offroad, that is night and day.
X 2.
My "light" 80 is still a dog with 5.29's, but I am in OD now most of the time around town and the torque converter locks at 42 mph in OD and 35 in 3rd with the OD off, so the tranny likes it more betterer, as well with the corrected speedo.
Your friend should be able to tell the difference on the speedometer. With 315's on and running 4.11's and having your speedo reading a lower speed than you are traveling, once the 4.88's are installed the speedo is reading a higher speed than you are traveling. This is hard to tell unless you have a GPS but will tell you the difference. The change is not a drastic change but you can tell from the transmission not down shifting as much as it did with the 4.11's.
I just had mine changed and I can hear more noise than I had before as the gears are breaking in but it is not loud by any means.
Tony hit on a good point, for your friend looking at the speedometer and comparing it to rpm, it would be the same, the thing is with the 4.88's the speedometer isn't correct anymore. Using a GPS while your driving is a godd way to check.
With 35 inch tires and 4.88's, your speedometer should be about 12% off
Guys..... Thanks for your help and assistance in this matter.... I will tell him to check the speedometer in comparison to when it had the 4.11.
I though there were gonna be a big difference, but since there are no hills in Fl it would be hard to notice...... I should be home soon and will do the gear test to make sure the right gears were installed... I will get a GPS and check the actual speed.....
Are the gears supposed to make a little bit of noise at first and then get a bit quiter?
If not I will tell him to take it to the shop to make sure everything's o.k.
Once again guys........ I feel better now since I had spent that much money on the gears, and I though it was in vain......
God bless IH8MUD!
One thing that wasnt mentioned. In my case, I had stock tires, gears and lift. Then I did all 3, 4.88's, 35's, and 4" lift. My truck feels the same, excellerates the same, shift points are the same, and cruises down the road the same. THAT IS WHAT YOU WANT, thats why you do the gear change. Is this what he is meaning? Because im sure that had I not re-geared, I would of noticed a difference.
