4.7 tundra
What would be a good tranny for this swap? I've heard that the 100 series has a better gear ratio then the 80's but I've also heard about the trans in the 80's ( 95 and up) being controlled electronically... is there a ( hate to say it) easy swap?
If the 1UR fits, how about a 3UR? Same block, should be OK, right?
You are talking 1uz and 3uz? The 1ur and 3ur are the generation after and the 3ur is much wider
Gah, you're right, the 4.7 was a UZ, I was thinking of the Tundra 4.6 and 5.7 UR engines... damn...
I was on the impression that the 4.7 bell housing bolts on the the 95.5+ trans.. so 4.7 motor + 4.7 bellhousing + 95.5 and up trans will work??
