4.5 water jacket fix
I did not snap any bef I welded it but it was clear the HG started leaking BC of the block electrolysis, it had less then 3/16 left on the back side of the triangle water jacket located in the rear of the block.
The new gasket uses a small round hole instead of the large triangle hole to send water through.
is 3/16 too little? how thick are the walls of the main rad hoses? and they are only rubber..... or the soft brass tubes in an older rad?
Its was lack of material that let the gasket go.
I built the back wall of the block back up to a little more than the stock thickness since the new gasket only has a small hole.
It was either that or replace the block, I got nothing to lose now.
I'm used to using silicone bronze rod & TIG w/ceramic blankets preheat, but here's a Mig method I pulled off the Miller site.
Silicon Bronze MIG Brazing Basics - MillerWelds
IDK anything about their way, but it's Miller - so their solution is mostly the "cost be damned, do it right once" -approach.
We routinely had to patch cast iron vessels before fiberglass took over as a cheaper & more cost effective vessel for using electricity to drop water vapor out of process flow (both in petro & chem) precipitators. That TIG method was ours, but that Miller article is worth a read.
If you have TIG at home, cheaper way would be the simple silicone bronze rod, figure out if you want to preheat - either way, a metal slug beats just slapping a HG over it.
Edit-forgot link.
Among the other problems with welding on cast iron, if you weld with steel filler it will create carbide inclusions where the weld metal mixes with the base metal. These are brittle and difficult to machine except with diamond abrasives. Nickel filler does not have this problem but it still has the problems with brittleness and cracking.
Sounds like one of the rare instances where epoxy might be a good solution.
