4.11 or 4.56
Vacaville, NorCal
I have an 85 FJ60 with the 4 speed transmission. I plan on keeping the four speed but go up to 33 inch tires. My question is what gear set up would be best if I will be going to 33 inch tires? I heard 4.11 would be best while the 4.56 would tend to be to high rpm at freeway speed. Did the search thing but did not find a satisfactory answer. :cheers:
Keeping the 4.11 will make it more likely to get a trail spare from a fellow Cruiserhead if you break. You may notice a little less pulling power in the hills. Worst case scenario give it a shot then if you decide you want lower gears you may have moved up in tire size too. It's not cheap to redo diffs, even if you do it yourself.
If it was me I'd keep the 4:11 for a 33. Not until a size 35 shoe would I consider a re gear. If you have 4:11 now and want 33s either way just put them on, drive it, then decide. The 2F in my 40 would do 33s easy with 4:10s but it has a fresh engine and drive train while for all we know you could be driving a rig thats a tired seeping time bomb with too many clicks and has been overloaded with heavy tools
Guys, I know this is somebody else's thread (sorry, Croozer:o), but now you´re talking about it anyway...
How do I know how big my diff is? Do I have to tear the whole thing apart, or is it written somewhere?
Thanx in advance,
Wim the bush whity
And Croozer, I'm sorry, but I can't give you any advice on this topic, because I probably know less about it than you:D
To determine an unknown ratio with open diffs, you lift one wheel and turn it TWICE; driveshaft revolutions = your gear ratio. If you're locked, lift both wheels and turn the wheels ONCE; driveshaft revolutions = gear ratio.
HTH
Butt
4.11s behind a 2F will turn 33s just fine. Even 35s. I didn't need 4.88s until I tried to turn 37s.
it all depends in what you like. I am running 33's with 4:11 gearing and thats basically stock if you wanna run a little bit lower gears go 4:56's I have drove a 60 with those and 33's also a 5 speed and it was awsome to drive
Thanx, Butt! Logical, actually. If I would have been smarter, maybe I could have come up with it myself.:banana:
Wim
It depends on how fast you want to (need to) drive on the freeway. I have 4.11's and 33's, and 2500rpm = 55, 3000 = 70. The truck actually feels best at 60 - 65, but sometimes I'm impatient, and "need" to drive 70. General opinion on here seems to be that 3000 is fine for continuous freeway driving, but shouldn't go higher.
So, with those numbers in mind...if you need to go 70, get the 4.11's. If you don't need to go faster than 63, then 4.56 gears will give you lower gears for off-road.
Playing with a gear calculator and thinking through how you use your truck is well worth the time. Thinking is free, gearing is expensive.
Trying to decide for 33 inch tires and 4 speed 4.11 or 4.56. There are some hills where I live. But need to drive at least 70 on the highway. The guy at the shop said 4.11 to 4.56 is not much of a jump.
I’d look at this chart and decide.
It really depends on what kind of tires you are using. BFG tires, for example, are notoriously undersized. I've seen side-by-side comparisons, and a 33" BFG will typically measure way under 33" - more like 31.5-32".
I decided to go with 4.56’s when adding lockers a while back. I’m running 33x10.50 BFG All Terrains with an h55 and it’s exactly what I was looking for; a little less downshifting up hills, but at a cost on the freeway. I’m looking at 2800 to 2900 rpms at 70 mph on the freeway which I’m ok with (I typically don’t get that thing much above 70). All in all the jump wasn’t that significant on paper but helped me out quite a bit in the hills.
