3sp t-case gears in a split case
San leon ,tx.
I've never seen a split case in person so I have to ask ..
Can you swap all the gears and shafts from a 3 speed transfer case to a split case ?
i.e. - If I have a cracked 3sp case ... But can get a split case shell for nothing ...
Not even similar.
Three speed.
Split case.
However I do know you can swap gears between the split cases.
Split case gearing: lower low range stock gears.
What @Gumby is saying is you can swap parts between some one peice cases. The three speed before 74 and four speed after 74 are both a one peice tcase with similar casting. Is it only the transition year that can swap?
You could upgrade to a split case they are better in manny ways. There is the parking brake issue as the drum parking brake on the back of the splitcase is rare. There is an aftermarket disc brake kit for that.
I have the h55 five speed with a split case in my 40 and love it. First gear is lower than the h42 and having the fifth gear dosent limit your top speed. @Bluebj42 is right about the parking brake. You have to find a split case with the drum parking brake super rare. Or swap in a 70 series complete rear axle with the drum parking brake cable wich is actually an easy swap. Or use the transfer case disc brake kit. Disc Brake Parking Brake Conversion Kit for Split Case [46550-Splitdiskkit] - $399.99 : CruiserParts.net, Toyota Landcruiser Parts also you will need a been tranny mount.
Hand brake for the split case is rare but not super rare. I just sold one and could probably locate another one.
You cane switch gear between split transfer case but those did have two sizes of idler shaft. 34MM and 38MM. Hand brake works on either.
I'm guessing you can't adapt the 3sp brake to work either ..
No axle swap for me . I'm already geared and locked
I have a later 4 speed one piece TC shell (from when I did an Orion) plus a complete 3 speed case for the gears, generally everything needed to build a four speed case with three speed gears (except a couple shims which can be bought from toyota)... always meant to try this but have not and probably will not ever get to it
will sell for cheap if anyone is interested... parts located in Des Moines IA ... could deliver in Denver next weekend or in May
PM me if anyone interested
Free three speed trans and transfer if you want to pick it up.
Dyno
If you want an H55, @joekatana had one for sale in the classifieds...and he’s in TX too.
