3FE stumble/hesitation.
Albemarle NC
I occasionally get a non-speed nor RPM related stumble hesistation while driving my 1992. It usually comes about when I am giving it very slight throttle while cruising, but persists no matter how much throttle given for about 5-10 seconds. Air filter is clean, fuel filter is less than 6 months/10k miles old, plugs are one year/10k old. I AM de-smogged, and my MAF has been richened 1 tooth.
And have you blown any EFI relays? Have you upgraded the magic wire in your fuse block? hmmmm?
Engine rebuild at 90k? Why?
Have you checked the air intake tube? Mine is so dry and cracked that if you lift up to check/change the air filter it will crack all over. Curtis, CJF, has mentioned that it has caused him many problems...he could give some good input on this subject. Mine is currently held together by a $hit ton of black duct tape. check around where that vacuum line connects too. Good luck, and Keep us updated
Dist cap and rotor worn??
Cap and rotor were replaced when the plugs were, along with plug wires, PCV, and almost all of my vacuum lines. The first owner had 100k warranty, and a family member worked at the Toyota dealership, I think it was just a free rebuild due to warranty.
Not me Jason; ya must be thinking of someone else. My guess would be a bad sparkplug wire. Curtis
Curtis, arent you on the Yahoo 3FE groups? That is where I remember you saying it caused you fits! Hmmmm
Filter sock at the pick-up in the fuel tank ever been replaced ..?
Just curious but what magic wire are you all talking about. I was a newbie in Dec.
Check a search for the EFI fuse and relay wire upgrade.
The 3FE stock wire is a little small and needs to be bigger.
In-tank sock has not been replaced, but the inline frame mounted filter has been. I reckon I could replace that sock, but that would force me to spend more money to get the entire truck's innards Reflex lined...and I don't need to spend even more money.
Any progress yet? I have had a similar symptom lately, I feel like im not getting enough fuel pressure sometimes. Im going to replace the fuel filter and in-tank sock soon. BTW alky i took my fuel pump out just to look at it and it literally takes about 10 minutes (i know you want to get your lining done but its really quick if your hoping to cure and or narrow down your hesitation culprit) anyone know if you can buy a temporary fuel pressure gauge or should I have a mechanic test it? Coil and Ignitor? I think I have my Relay thing fixed but Im going to buy a new relay for the summer anyways.
How severe is the stumble? (just noticable or "holy sh*t, what was that?)
When it occurs at low RPM will it stall?
Does engine temp have any effect?
Will it do it in neutral (no load on the motor).
Well, it's the exact same effect as someone turning off the ignition via the key. It can happen whenever, from a dead stop, while cruising down the highway, on a side street, whatever...it has done it. Temp doesn't have an effect, ice cold or hot to trot no change. In neutral, no clue. Parked it will sometimes get rough for a few seconds then smooth back out.
