I have a 1991 cruiser with the 3FE engine. It has just over 60k miles on it. The previous owner had over heated it badly. I took it all apart and found blown head gasket and a few of the pistons were starting to melt from over heat. I put all new pistons and rings in and all new gaskets of course. Also installed new 4 hole bosh injectors with the jumper harness. Now I start it and it runs rough, in neutral at low idle i can just barely hear a miss, but once I put it into gear(forward or reverse) it gets much worse. It'll drive, but not very well. I have readjusted the valves when the engine was hot and set them pretty tight which is possibly the problem? I just checked compression and it was way low, in the 50 psi range for most of the cylinders. I thought that since they were all that low that maybe I adjusted all the valves on the wrong TDC, but I have it turned to TDC #6 right now and the number 6 valves are loose and ready to be adjusted as they should be. I can unplug the #2 spark plug wire and the engine runs the same, so I figured it might be bad wires so I replaced those but still the same. Checked for spark with the plug out of the hole and I am getting plenty of it. Then I checked to make sure that my injector was plugged in and it was. I even switched the plugs for one and two injectors just to make sure that my wires werent bad, and it effected the engine each time I unplugged and plugged them back in, so my wires are fine.
Any thoughts or help would be awesome, I have the valve cover off right now going to check into my valves some more...
