Newer EFI systems use a Pulse Width Modification (PWM) method of controlling the fuel pressure. Some have a constant bleed in the system somewhere, others do not.Yeah, I've heard of converting new style "deadhead" EFI fuel systems to a return line but never the other way around. I'm not sure why OEMs have gone to the deadhead style in recent years. I'd be very interested in hearing more if anyone has insight into the pros/cons of deadhead vs. return line designs for EFI fuel systems.
For those unfamiliar, PWM is simply turning the pump on and off at, say, 30 times per second. How long it is on vs. how long it is off is "Duty Cycle". More Duty Cycle, more fuel pressure.
With this method you can run the system deadheaded and don't need an FPR, but you do need a computer monitoring the pressure and adjusting the PWM on the fly.
The only advantage to deadheaded that I can see is less pressure pulsation in the fuel rails, so each injection should be more consistent.
Personally, I would use the Bosch or the Walbro 255 liter per hour pump over the MSD pump. Those pumps are designed with a high MTBF rating like an OE pump. I don't know that the MSD units are.
Cool , so it is more of a constant pressure vs constant volume adaptation.. Interesting.
EFI main relay was bad. Cranks and runs great now. Heading out for a test run and first fillup.
So I thought about this comment some more - wouldn't the constant volume pump combined with Fuel Pressure Regulator, fuel pulsation damper and return line basically equal constant pressure?
