Hey guys, I have a 1991 fj80 with the 3fe 250k miles. I am replacing the rear main seal gasket and valve cover gasket due to leaks. Rear main seal requires transmission to be dropped/pushed back. Is there anything I should do for preventative maintenance while I have that off/moved? Same for the valve cover gasket. Anything I could also clean, replace or do to keep engine running as long as possible? Thank you in advance!
