3fe coil ground
Temecula
I was replacing some heater hoses today and found the ground that runs from the bottom of the coil was not connected to anything. I have no idea how long it has been like this (since I got it?) or what is the purpose. My question is where does the coil ground to? I noticed an empty threaded hole on Charcoal canister bracket, the threads matched and the wire looked like it may go there so I hooked it up to that. Is this correct? Where does it normally go? Does it matter?
Actually I think it is the igniter ground. It has the ground right under it to the mounting bracket than the other ground that is pretty long 10" or so that I am trying to find out where it is supposed to go.
Yeah I would guess it is a tach thing but it has always worked so? I'll take a picture.
Here is the plug. It goes to a smaller plug then a single wire with a ring terminal I am thinking must be a ground. Also does an igniter show any signs of going out or is it all or nothing. I have a stumble when underload mostly up hills but only occurs sometimes. No idea when it will happen. Also have a rough idle. 99% of the time I have no problems but I am always worried all is going to go bad.
There is no ground wire for the coil or the ignitor. Coil does not need to be grounded. Ignitor is grounded via its mounting.
Mark...
So what is the point of the ground wire that is running out of the bottom of the igniter. I can take a better picture if necessary.
Do you have an EWD? The diagram shows a splice near the igniter, with one of the legs going to a "noise filter". Normally a noise filter needs to be grounded, so the electrical noise can be eliminated. This is on the IG- wire, which also feeds the tach in your dash and the IG- terminal in the Check Connector.
HTH
I have the electronic FSM and could not find a wiring diagram that describes the igniter wires. That sounds like what it is as it has 2 legs and then goes into 1 for the ground. Thanks for the info.
