Im prob gonna get a few responses spankin me for askin this but I want to take the F1 engine out and replace it with as new a motor as I can get, Im thinkin a 3F-EFI. Not sure if it will fit in my 66 FJ40 without all kinds of mods. Hope Im wrong, maybe you guys can help.....
It will fit. But there are "issues." Some that come to mind are:
- There is a fuel line that runs behind the head. It will hit the firewall.
- The 3FE airbox will not fit under your hood without mucho mods. A cone filter adapter for a Supra will adapt to the AFM. These are cheap on
Ebay.
- You will need to install an electric fuel pump that puts out 40PSI (IIRC). I believe an aftermaket pump for a Mustang works.
- You will need to deal with accessories (alternator, PS, smog pump) though I don't see any of these as difficult.
- Your brake master cylinder will probably be in the way of the plenum. If you have installed a brake booster you will have issues.
- Then there is the wire harness. You need both the motor harness and the main, fuseblock harness. The motor harness is used unmolsted. The main harness needs to be dissected to just the EFI parts (there are two, I can't remember which ... ignitor and a relay?). Of course, this fuseblock could also be used to rewire your FJ40, only taking out the FJ62 specific items. Make sure your harnesses come from the SAME DONOR and they are NOT CUT (don't ask me how I know). The harness in 1988 is NOT the same as the harness in 1989 (again, don't ask how I know). Also, some of the sensors are different between 1988 and 1989 (do you get the feeling I might have learned a few things the hard way?)
This project cannot be accomplished without the factory service manual. CANNOT! Because of the wiring differences make sure to get the manual specific to your donor [sigh]. There is another document out there, "1988_FJ62_New_Features.PDF" that was absolutely valuable in understanding what I could nuke, vs what I needed to keep and why.
Bottom line, if you don't have a complete donor (I didn't) you could have difficulty obtaining all the parts you need. If you are serious about this swap, read everything you can, and study the electical diagrams in the FSM, before you start. Also, there's not too many folks that have done this swap into an FJ40, so you will need to be creative as you are treading on new ground.
