3F-E Head Clean, Inspection, etc.
Ann Arbor, MI
Not now, but at some point in the future, my 3F-E head will need a clean-up. When I had the cover off last, there was a LOT of caked up oil all over inside.
This is not really something I want to do myself because I know it will take me entirely too much time. However, I do want to budget for the work to be done so I don't have to think about that later either.
My question is this:
What should it cost to get the head properly cleaned, new valve seals, re-grind the valves, etc. Assuming everything can be re-used(except the valve seals).
Also, is there anything I need to watch out for after this? Anything I'm not considering that should be done at the same time?
What say the Collective Experience?
Your best bet is to ask the shop doing the work. You will save yourself a lot of money if you remove the head and take it to a reputable machine shop who has experience with a 3F. A lot more money saved reinstalling the head. It's a good bit of work but it's far from difficult.
I'm pretty sure that these shops with 3F experience are a myth. I live in Michigan, very near Detroit. I can't imagine that this head is so much different than any other head and there are a LOT of shops in Detroit which can do the work with no problem.
The plan is definitely to remove it myself and take it in, but I'd like to make sure I know what to ask for from others who have done something similar. I'd like to minimize my down-time when I get to this.
Is the head gasket suspect? (Blackstone oil analysis?) Or are those stem seals really leaking? If not, I'd recommend leaving things alone. My $0.02.
Had mine decked .02 and also desmogged during the process. Runs smoother & better mpgs, can't tell if any power gained.
No, it is a 3FE, the head gasket is never suspect... But, if I'm already removing it for cleaning, I might as well replace something that could wear. I'll check the FSM to see if there anything about confirming wear on the valve seals.
I kinda planned on this already too. I want to lose some vacuum hoses and that silly air pump and replace it with a York compressor(for fun).
"No, it is a 3FE, the head gasket is never suspect... But, if I'm already removing it for cleaning, I might as well replace something that could wear. I'll check the FSM to see if there anything about confirming wear on the valve seals."
With this in mind, I definitely wouldn't remove it for cleaning. I just know a lot about fixing things that aren't broke! But, if you're like me... jump in!
Getting rid of the smog and air system was the best thing I've done. Hands-down
You have no idea... I started replacing a couple rusted brake lines 2 years ago. Now I don't even have axles under the truck and it hasn't moved since I started the brake lines. I don't mind knowing I'll probably never have to do any of this again.
THE MIGHTY 3FE!!!
I have all of the parts for my EGR delete. I just need the time...
I want the space for a second battery. How big is the York? Could I have both?! Hmmm
apoligies to @jonheld for stealing his picture...
This is how the engine room looks with a York compressor. It is a little tight, but it works.
In order to add a second battery on the LH side, you'd have to remove the weird cooling blower stuff.
You could add a second battery in the huge space on the passenger side though.
I'm removing that weird cooling blower motor stuff too. All of it must go! Which York compressor is that?
I believe it is a York 210L.
Do a search on here for "York Compressor" or "York OBA" (On Board Air)
There is a bit of information on here about this sort of setup.
Also check out jonheld's site: http://www.sdsysdesign.com/tlc/oba.html
I will do more research on it when the time and money comes. Ideally I'd like to have the York OBA AND the second battery on the driver's side using a 93-97 battery box. Just so that it looks clean. I really don't air down my tires much but it sure would be handy from time to time. Plus I think it would be cool as s***! :) Which, when it comes down to it is probably the best reason to do any thing to your 80!
How many miles on the engine? I had my 3FE head worked over for my 2FE conversion. The donor had about 248K on it. When they took the valves out, the machinist showed me the "stepping"on the valves. I was converting to SS Chevy valves anyway, but the machinist said he would have recommended replacing them with new valves had I not been swapping them out. They also drilled, tapped and plugged the oil galley.
So, chances are, depending on your mileage, your valves will also be stepped and if you are going through the trouble of having the head machined, you might as well replace them.
The engine only has 190k miles on it. 3/4's of the way to the moon!
If you do get it checked and they recommend replacing the valves and the valve guides are out of spec. (not likely) then you might want to consider going with the Chevy valves since the machine shop can ream the guides and grind the valve seats to fit the chevy valves.
