If You frequent the Diesel Tech forum you know Diesel42.
If You know about turbo kits for the 3B You know Diesel 42 makes one exclusively for 'Mud Members.
D42 has sold many of these kits to 'Mudders but no one has really described his kit in detail after buying one.
First let's start with the install.
Pulled the old exhaust manifold
IMG_0250 by
Brompton Photography, on Flickr
IMG_0248 by
Dry Fit the new one... Yep gonna have to re route those heater lines
IMG_0251 by
Pulled my Push Rod Cover..... 2Hrs to get it off, 1Hr to get the gasket off of the cover and 3 more Hrs to get the rest of the gasket off of the block! I hate those gaskets.
A side note... Check for dishing on your cover if there is any dishing around the bolt holes gently tap them as flush as possible with a hammer and brass block.
photo 2 by
Painted and re-installed Push Rod Cover with cork gasket and Permatex FormAGasket #2 both sides. did not over tighten.
IMG_0259 by
Re-routed heater lines, dropped oil pan, welded bung, Painted pan, re-installed with new OEM pan gasket. removed oil plug from side of block for oil feed line replaced with supplied fitting.
D42's kit comes with 99% of everything you need to do this. He even includes the silicone hose adapters for the throttle body and the compressor outlet. The only pieces I had to purchase separately was connections from air cleaner to compressor inlet, the pipe to go from the turbo to the throttle body and exhaust flange.
Here's the turbo being installed on the manifold.
IMG_0267 by
I lucked out at the metal superstore and got a 12" piece of 2" stainless pipe for 2CAD fit perfectly between my turbo and throttle body
IMG_0268 by
After the turbo was in place, I torqued all my fittings for the oil lines and hoses etc. For the air cleaner to the turbo i bought a 3"-2" silicone reducer a 2" coupler and a 45 degree 2" exhaust pipe. total of about 100CAD. Expensive when I could have used a piece of central vac hose I'm sure it would have done the trick but this way it looked consistent with D42s kit.
I had a local exhaust shop do the connection to my existing 2.25" muffler-ed exhaust setup. it was pricey but it looks great.
Here is the final install.
IMG_0272 by
Also not included in the kit of course is your choice of gauges. I went with the Auto Meter Ultra Light II series Electric Pyro and Mechanical Boost gauges. They are temporarily taking up my ash tray slot but do not like them there. They will be moved one day in the near future.
Stay Tuned for Performance Review tomorrow...
