I know that so many talk about this..
But I hve seen nothing that is CLEAR..
One thing that one HAS OR DOESN"T have..
Mine seems to have some features of the 3BII and the 3B also??????????
Thanks
Todd
Ok.. so I have a 3B.. with the long exhaust manifold that dumps out the back..
Can someone define "JDM" .. I see it on the forums.. but I do not know what it is..
Thanks a ton guys-
Todd
Todd
Sorry to break it to you, but a BJ61 exists as a JDM model....WHAT!? A BJ61? Can't be.
The JDM's were called BJ60 from 1980/08 until 1982/10 and BJ61 from 1982/10 until 1986/08 when the 3B powered 60 was dropped from the Japanese market. The switch from inline to rotary injection pump happened in 1982/10 - i dont know if this was the reason for the swtich from 60 to 61 though.
Do both the 3B and 3BII have just "3B" here on the casting?
...It looks like it Tom. This is the only picture i have of a 3BII, you can just make out the cast 3B behind the dipstick tube. Note the timing case mounted vacuum pump under the injection pump, which is another 3BII spotting feature. ...And heres the difference between the 8 stud 3B and ten stud 3BII exhaust manifold bolt pattern....
Edit: He got much closer than I thought, and lists an FJ61 as well...
thu LC: Toyota Land Cruiser History
But no BJ62 or HJ62...
Additional codes
DESTINATION: JPN: JAPAN
BODY: WGV: STATION WAGON
ROOF: SRF: STANDARD ROOF
ENGINE: 2F: 4200CC
FUEL SYSTEM: CBR: CARBURETOR (GASOLINE)
TRANSMISSION: MTM: MANUAL TRANSMISSION
GEAR SHIFT TYPE: 4F: MTM, 4-SPEED FLOOR SHIFT
BACK DOOR: VKC: VAN (HARDTOP), WITH SWING OUT BACK DOOR
Search Results
VIN* Model code From To Frame Characteristics
04651016.. FJ61V-KC 10/1982 - 10/1984 FJ61 JPN WGV SRF 2F CBR MTM 4F VKC CBU
.. FJ61V-KCH4 10/1982 - 10/1984 FJ61 JPN WGV SRF 2F CBR MTM 4F VKC IV4
Forgive my ignorance, what is the EPC?
