Been considering that too. Do you have a source for that? The stock offset is listed @ 35 for stock rims. 25/60 range. But i did not know a thing about all this when i started. Live and learn.Stock offset is 60mm. Yes, 25-40mm would be more ideal. Consider doing a 1" body lift.
This is an extremely confusing subject found only in the 100 section of MUD. Possibly infecting the Prado and 200 section too? Idunno.
Why? 35's are 35/12.5R17 or R16. Most often including the 315 metric equivalent - only. Not 285/75R17. Not 295/70R18. Most every thread referenced above turns into tech relating to tall skinnies mistakenly being called 35's based on height - not profile.
Hope you feel better my friend.Ok, so I read this a few times and it's driving me nuts. "mistakenly being called 35's based on height - not on profile"
35 means height, and has NOTHING to do with profile. NOTHING. So there's no "mistakenly" . The reason everyone is quoting metric sizes is because a lot of manufacturers have thinned down there SAE sizes. I too am "not trying to be a dick", but 35" tall is 35" tall is 35" tall, regardless if it's a skinny. Furthermore, a 285 is 11.22" wide, about 1/4" narrower than a 11.50". Furthermore, a 295 is 11.60", which is over 11.50". They make a Super Swamper in a 35x10.50x17 and it's still a 35" tire ...... because the width has NOTHING to do with the fact that it's 35" in diameter.
Just had to get that off my chest.
I don't know about "better", but I feel "accurate"
I understand you are being specific to "12.50", and that's what I think you mean to say ... "in 12.50 width", because 35" are available in other widths.
@ scoonr : You're wanting to fit true 35's? The wider tires most likely around 34.7 x 12.5 .... I needed 2.5" lift, 1" body lift, new UCA's, diff drop, new torsion bars, wheel spacers and pinch weld hammering. Or you could SAS the front which might be close to the same cost DIY. Depends on what your specific needs are and skill level. In hindsight, if I were to start fresh with a pocket full of change, that's what I would do.
When in doubt, call a vendor on here. GL
I ran 255's on an 81 for 60k miles. Literally every type of terrain including snow and sand. When asked what size tires I had by other overlanders, I would say 255's - not 33's or 285's. Because offroad they handle differently which is really what people who own land cruisers care about. And why 35's are different from tall skinnies. Profile. But agree to disagree
Wow yours are a lot tighter than mine are.
Thankful I wasn't about to see another @ShottsUZJ100 poser thread starting...that picture brought back nightmares of time i'll never get back.
I miss him![]()
