spartan said:315 / 35 BFG MT'S are nominally 35 inch tires. Actually larger diameter than BFG AT's.
No offense, but if you stuffed 35's under a non-lifted 80 it's a mall cruiser plain and simple.
You will need J springs and other stuff to make 35's really work on an 80. Not to mention you are way under geared.
It's official allright. Your tires are too big. Big tire for the sake of big tire, when smaller ones would do a better job and cost less.
To everyone his own. Good luck.
spartan said:No offense, but if you stuffed 35's under a non-lifted 80 it's a mall cruiser plain and simple.
spartan said:" The trend for trail rigs is less lift, more tire.The trend for trail rigs is less lift, more tire. "
Trend? Suprise to me. That's the way it's been done since I started off-roading Landcruisers in 1977. You guys just figure this out last week?
spartan said:" The trend for trail rigs is less lift, more tire. "
Wow - next thing you know there will be trends to run lower air pressure off road, carry a Hi-Lift jack and learn how to put a tire on the rock.
NorCalDoug said:I don't have J coils.
I'm the low-rider of the group of guys I run trails with.
spartan said:Next - start a piss fight and you will have to stay with the facts. Your unlifted 80 will not off road in serious terrain with 35's without major rubbing and binding. You guys take a couple of pics of your truck on a drainage ditch and claim it's perfect with 35's. I call BS because you've never been on a real off road trail.
You HAVE to run X amount of lift to achieve Y articluation with Z tires. That's it plain and simple. It's your problem, not mine, so just leave me the f**k out of it. Go and talk to another wall. Thank you.
My last comment on this subject for those who should know better.
Spydaz said:Here she is, i do not need to regear at all, the stock gearing turns these babys just fine.... First test run on the beach in Montauk point, took the beach from the point to west hampton, no problem.
Spydaz said:Land: I am having the 30mm Spacers from man-a-fre installed for the rear as we speak. I hope she does not come out with the stinkbug, i don't think she will. Extra inch on the rear springs should not make a stinkbug should it??
FirstToy said:Here is a photo of NorcalDoug on the Rubicon w/ OME Heavy 2.5" & 35's
Unless you lowered the bumpstops, I will predict you will still rub in similar situations that you did before the spacers.Spydaz said:Nice, well just got it back and it looks awesome!!!! No Stink bug!!!! No Rubbing in the rear!!!
Agree, just saying that without lowered bumstops, the tires will likely still rub, as there is really nothing to prevent it, travel would be very limited w/out lift. Basically the 35's will likely still rub w/out lift and lowered bumpstops, in similar situations.Land Speeder said:Can't really lower the bumpstops on factory ride height... I mean they could but then the stops would be hitting while traveling over small bumps.
I guess they could be lowered as much as is gained in lift though.
