315's / 4.88 speedo/odo data
The Old Pueblo
Just a little info for those curious.
About 6 weeks ago I had a set of Cooper Discoverer STT in 315/75 r16 installed on my rig. Now recently I have had 4.88 Yukon gears installed in the rear. I’ll have the fronts in soon along with an ARB front locker.
Over this last weekend I used my Garmin Geko 201 GPS to track MPH and miles driven.
Looking at the speedo and then down at the GPS I determined as best I could that my speedo reads appx 3.5 MPH faster than I am really going.
Tracking the miles I found that when the GPS turned 20 my odo said 21.7. Multiply that x5 and you get 8.5 miles over for every 100 traveled.
I haven’t tracked MPG yet since the gear/locker install is not complete.
You're driving around with 4.88's in the rear and 4.11's in the front?!? :eek:
Have you removed the front driveshaft?
If not, I foresee a new vc/transfer case in your future... :frown:
I recently drove from Austin, TX to Atlanta, GA on 35s Swamper SSRs and 4.88s. 5 tanks and I was still going once in ATL and drove around for a few days before filling up.
Trip was about 1000 miles on the nose...burnt about 78 gallons, so about 13 mpg. It was a tooth rattling trip with the old swampers bumping and jumping the whole way. I expect this will improve with the new MTRs being mounted as we speak.
MaddBaggins said:
... you get 8.5 miles over for every 100 traveled.
8.5% sounds about right. You realize that percentage will translate to both the speedometer and the odometer, meaning that your +3.5 MPH on the speedometer is only at a set speed (I'm too lazy to do the math.)
at 80MPH indicated, you will be travelling 73.2MPH actual (8.5% error)
-B-
Yeaaahhh, I don't even wanna know what it would drive like in that config.
Front DS is on the floor in the garage. I just figured it goes without saying that the DS is removed, but you're right, some rookies might read this and not get that part.
-B-
The +3.5 was int he 40mph range going crosstown. I checked it early one morning at 55mph on the speedo and it read about 4 or so over.
Get a tru speed calibrator. Helps with shift points etc. Set it up with a GPS. Get it from slee and use their installation instructions.
Cheers,
Sean
