Speaking of the lift gate. Does anyone else have problems getting the touch free open to work. All it ever does is beep at me. Is there some logic to make it work?
There could be a chance it’s the anti pinch sensors along of the edge of the hatch. Gently massage the edges and try again. If still no good I’d take it in for the dealer to test.It does not move. It just beeps twice. I switched to the regular key to see if that would make a difference and opened the hatch with the button but I still had to shut it manually.
Yes, the credit card key is lame and only works 75% of the time. It USUALLY works all the time with the regular key though.Speaking of the lift gate. Does anyone else have problems getting the touch free open to work. All it ever does is beep at me. Is there some logic to make it work?
In my 700 I swear it only works when I do NOT want to. Like, if I am picking up something in the boot or installing the tow hook, then it detects my foot and sometimes attempts to close - then I have to hold it - or it just keeps beeping complaining I am under it. I could NEVER make it work as intended. It is very lame. It is literally the only thing that does not function properly in my car. Such a gimmicky useless thing.Yes, the credit card key is lame and only works 75% of the time. It USUALLY works all the time with the regular key though.
Yes, it's in the vehicle customization menu on the main center panel if memory serves.In my 700 I swear it only works when I do NOT want to. Like, if I am picking up something in the boot or installing the tow hook, then it detects my foot and sometimes attempts to close - then I have to hold it - or it just keeps beeping complaining I am under it. I could NEVER make it work as intended. It is very lame. It is literally the only thing that does not function properly in my car. Such a gimmicky useless thing.
Is there a way to deactivate it so it stops triggering when I am under it?
weird i don't use the credit card and only a regular keyYes, the credit card key is lame and only works 75% of the time. It USUALLY works all the time with the regular key though.
CC key is awesome. Now that i mostly drive a daily driver, i find ut annoying that i have this key fob in my pocket. CCK just stays in my slim wallet and go on with my day.weird i don't use the credit card and only a regular key
I agree, it’s very convenient in all aspects and I carry it most of the time…it’s good except for the rear hatch.CC key is awesome. Now that i mostly drive a daily driver, i find ut annoying that i have this key fob in my pocket. CCK just stays in my slim wallet and go on with my day.
Center diff locker stopped working. Thought it was a battery issue, took it to the dealer. Diagnosed with an "internal failure" in the actuator. Getting a replacement under warranty. Will see how it turns out next week!
Found it. OFF now. Thank God!Yes, it's in the vehicle customization menu on the main center panel if memory serves.
They replaced the whole thing, not only the harness? No charges and all under warranty?proceeded with actuator replacement, drain fluid, disassembled, cleaned off sealing surfaces, replaced actuator, sealed transfer case, installed and topped off fluid. rechecked."
The early 200s had the same issue, then a TSB advised the replacement of the rear drive shaft with one having a different spline profile. Problem gone.2022-24 LX600. Clunk into first gear during acceleration during a rolling stop, but also sometimes during highway driving and downshifting (6th-5th gear).
Solution: no solution, innate design flaw.
Partial solutions:
-You can alter your driving style with gentle pressure on the gas while the computer figures it out, then accelerate after the down shift.
-larger tires make the clunk less noticeable.
Extra comments:
I suspect the design anticipated the hybrid system, as the clunk is completely gone with the Lx700h, and the electric motor provides torque during engine start up from start/stop and also during highway passing maneuvers.
I would still be driving my 2022 with the above partial solutions. It was not a killer problem for me.
Update. I tried the tailgate yesterday and still didn't work. I tried it again today and it started working. Maybe there is an electrical gremlin somewhere in the system.Today the tailgate on my 24 LX600 won't go down. It just beeps a couple of times. It opens fine but has to be shut manually (all the while it beeps in anger). Any ideas on how to rectify the problem will be greatly appreciated!!
Issue is detailed on another thread. Had same issue with my 2024 with about 7K miles on it. Was the pinch sensor on one side of the tailgate. Both sides’ sensors replaced under warranty. Common issue on LX, RX, NX, etc.Update. I tried the tailgate yesterday and still didn't work. I tried it again today and it started working. Maybe there is an electrical gremlin somewhere in the system.
Update. Dealership is replacing the sensors on both sides. They said it would have cost over $1K if I had to pay for it.Update. I tried the tailgate yesterday and still didn't work. I tried it again today and it started working. Maybe there is an electrical gremlin somewhere in the system.
IIRC, I think it will "remember" eco, comfort and normal (anything equal or more fuel efficient than normal) but the sports modes need to be re-selected every time. Likely another fuel economy thing..Odd thing I noticed today...
The 600 will not retain it's last "mode" when you shut the car off (ie. driving in normal, sport, sport +) shut the truck off, then turn it on again it defaults back to "normal"
I was experimenting with "eco mode" and oddly enough, it retains "eco mode" when you turn the truck off an start it up again. How weird.
Yep, same with me. Tried to use custom, but it won't retain after shutting off and defaults back to Normal. Eco, Comfort and Normal stay on after shutting off. I rarely use Sport or Sport+ (just when passing others in two lane roads). I just leave in Comfort now. IMO it is the most fitting mode to a Cruiser, although sometimes the floatniess is too much when going through tight corners. Other than that, it just floats over bumps and imperfections as intended.IIRC, I think it will "remember" eco, comfort and normal (anything equal or more fuel efficient than normal) but the sports modes need to be re-selected every time. Likely another fuel economy thing..
