3 Weeks in Colorado
Athens, GA
Website
rainmakerwebdesign.com
I've been traveling around the country for about 16-17 months now, and it's high time to end it with a bang. A week from this posting, I should be in fly-over country pushing my new addiction as fast as this 5000 pound beast will go. I've got ACL reconstruction next month, so before I spend a long rainy Southern winter rehabbing it, I'm hoping to bag trout and some trail time.
See, a couple months ago this guy was nice enough to be checking his phone just outside Durham while I was turning left to grab some coffee en route to Delaware. Problem was, he was cruising at 45 and I was stopped dead in my Volvo Cross Country. Skid, bang, crunch, crunch and my hat that was on my head, was then resting in the rear cargo area. Without his help, I'd still be that lame dude driving a Volvo.
After that car's untimely death, it was only a '98, I felt I needed something iconic and durable, tank like really. So with insurance check in hand, I searched, and found what I hope will be a worthy travel companion, my "new" '92 FJ80.
Some here might think it was overpriced a bit, but I felt like it came from a good home, and had some of the major work done before hand that might be expected before it really got broken in around 200k. Thanks to the good people here on Mud, I knew a few gotchas to look for and avoid.
Before I head out, I've got some preemptive things done to it, several more to do, but I would simply love to know what y'all would do before heading out and if there are any commonly overlooked spare parts or tools I should toss in back?
Post some pics!
Baseline/tune-up essentials if you don't know that these have already been addressed: http://www.sdsysdesign.com/tlc/images/Strife/3FE TuneUp.pdf
Until you have some time with your new ride and have gone-thru systems, this is good to understand in case you experience starting problems that aren't related to battery/alternator: http://www.sdsysdesign.com/tlc/images/Strife/3FE EFI Diag.pdf
At some point, you'll find yourself tinkering with the AFM. Removing the wiring harness is done by removing little metal clips that hold it in place (thin metal, the thickness of a smaller paperclip). Do NOT remove the two screws that appear to be holding the harness in place - if you do that and then try to pull the harness out you wind up destroying the soldered electrical connections and will likely need to replace the AFM itself. Save yourself the headache, just avoid the "two screws of death".
Pick up a spare EFI relay to keep in the glovebox, keep a Factory Service Manual (FSM) with you, fluids/tools for your road trip, multimeter.
Do go thru the maintenance items of the FSM - it'll identify for you all the items which need to be replaced at certain intervals/mileage (some of which are covered against the tun-up checklist above). 200K on the '92 is JUST FINE provided she's being treated well. Regular fluid changes are the primary items to keep the tractor running smooth, but a variety of consumables need to be swapped out with new OEM replacements. You'll get a good sense for those items in the first link but again, get to know the FSM.
Grease your drive shafts/u-joint zerks (6 total - u joints (4) until you hear grease burping, just a few squeezes for the drive shafts (one zerk each), don't overdo these), give the driveshafts (front and rear) a good inspection (looking to see if it's loose/has play which would indicate u-joint replacement needs); ensure your diff fluid levels are topped off and there's grease in the knuckles.
Pre-road trip/new to you - ensure the coolant is fresh - flush and go with 50/50 mix of distilled water/Toyota Red if you have doubts.
Chances are you can go on your road trip without doing a darn thing and it'll be just fine. Threw a lot at you here, don't let the list throw you off.
Enjoy the '92 and your 3FE. She's a bit underpowered but trustworthy like no other. Welcome aboard!
Don't forget some pictures of the rig, the trout and the trails you find yourself on. Have a good trip.....
tlin, thanks so much for being the man! Nah, the list is perfect and much appreciated. I'll turn this thread into a trip report as it progresses.
Found several things that were not on my list, here's what's been done, what I'm doing before I leave, and extra parts/tools to load up. This may be more for my reference, but if it helps out any other rookies on here I'd be very happy.
Done + History
- Rig has 218k on the clock. Had some drive train clunking, sounds like they all do, fluid swap minimized most of it (except shifting into R). Nearly stock, 31x10.5x15 in good condition, and not a lick of rust on her.
- Valve Cover Gasket @ 151k
- Front Axle Service @ 161k, probably due again
- New Alternator @ 180k
- New Radiator @ 181k
- Transmission & Torque Converter rebuilt by PO with transmission cooler @ 198k
- Coolant Flush @ 206k
- Replaced both diff fluids, transfer case fluid, 215k
- Leaks at rear main seal and oil pan gasket, added Bar Stop Leak, seems to have fixed both for the most part.
- Adjusted Kickdown cable 216k
- Replaced Battery 216k
- New CDL Switch, CDL indicator works like a charm @ 218k
- Replaced Air Tube over Valve Cover @ 218k, PO had it duct taped. Probably was leaking, idles better already.
- Replaced Headlights @ 218k
To Do This Weekend
- Replace Plugs, Wires, Cap, Rotor, Cap Gasket, and Cap Rubber Cover
- Clean K&N Air Filter installed by PO
- Replace PCV Valve and Grommet (thanks tlin)
- Download Service Manual
- Download EFI Diagnostic Document
- Grease & Inspect U-Joints + Drive Shafts (thanks tlin)
- EGR Valve, Gasket, Modulator (thanks tlin)
- Vacuum lines and valve adjustment may have to wait - lines look pretty good, hoping to get a little more comfortable with wrenching stuff before doing the valve adjustments. Am I nuts?
Fuel Filter Assembly + Fuel Filter Sock
Tools (Beyond the normal sockets, etc).
- Multi-meter
- What else?
Spare Parts/Fluids to Bring
- EFI Relay - tlin, I would have never thought of this one!
- ATF Fluid
- Oil
- Toyota Red Coolant
- Gear Oil
- Spare Fuses (2 assortment packs)
- Spare Belts (2)
- Beer. If I'm stuck, might as well have fun.
No need to thank me, thank Mud. I knew nothing other than "Land Cruisers are cool" before buying my '92 2.5 years ago....learned just about everything I know thru this group. Have had zero problems with mine other than wishing I could get up freeway hills a good bit faster.
No, you're not nuts putting off vac lines or valve adjustment a bit if the rig is running well. You'd know if you had some problems with vac lines and would probably be able to hear if your valves are really in dire need of an adjustment.
If the front birfirlds were done right don't redo them just yet. It is a very doable job but a big one and you would be better of with other things before the trip. Just be sure to check that there is grease in the birfields .also check your break pads! Consider repacking or replacing wheel bearings. If you are on a budget ant the wheel bearings feel good, repacking is a valid option and is part of the schedualed maintenance. Drive line should be brakes (inspect and replace), wheel bearings, drive shaft joint, and check for obvoiuse problems. Spend some time laying under their drunking a beer and looking at everything. Also tighten the 4 17mm nuts on the bottom of each knuckle!!! In addition to drive line do the base line you just did. Fusable links are cheap and easy, a must. Belts and fluids are a must. Personally I think coolant system is a MUST!!!. If your coolant hoses are original they would be at the TOP of list. A full set of OEM fr one of our guys is under 150 I think. At least do the Hosea and thermostat. Think about this. The PHH is a $5 part that will put you dead in the water or with a destroid motor in a heart beat. This has nothing to do with how well designed a Toyota is. It is simple physics of what happens to rubber parts after 20 years of heat and use. In my mind every rubber part on these trucks needs to be replaced. Start with coolant system ( sees a lot of heat). Then break system because it is critical. Then oil leaks and then just keep going over time.
Let me also say this. It is common advice not to do major repairs the day before you head out. So get agressive about doing repairs right now. That way you can fave everything ready for a week or so before you leave. You can make sure your work is good. Last thing you want is to crack your radiator pulling off a old hose the night before you head out.
rc51kid: the coolant hoses look pretty good, think the PO might have had them done when the radiator was replaced around 160k.
PHH? Do the 3FE's have this issue? I understood that it was the newer FJZ engines that had this Achilles heal on them?
"It is common advice not to do major repairs the day before you head out." - Now I'm worried LOL. Think I'll take a quick trip up to the North GA mountains for a day or two to test everything out. So between a few trails in GA, and 1500 miles of interstate before Denver, hopefully I'll have the kinks worked out.
PHH - not a 3FE issue.
It is not really a Achilles heal. It is just a coolant hose that is 20 years old. It can be tricky to replace but nothing major. It it fails it is no better or worse than any other coolant hose.
speaking of traveling i think our fj80s need the fifth speed folks last july i drove my 93 to disneyland and colorado at around 80mph and i was passing by other newer cars and suv that went over 100mph i had no way of catching up with them what i am trying to say is it's nice if we have a 5 speed tranny
I don't know if it is gearing. But don't think my 80 would pull 100+ regardless of gearing. Personally I don't want to drive It at over 100mph but that is just me. I enjoy bumping down the road at 65 mph
