Wanted 3-speed column shift assembly.
Portland, OR
Hello,
I just bought a fairly clean 1969 FJ40 that someone did a hack job V8 install. I would like to put the 3 speed column shift back in. The only thing I have left of the three speed is the lower pivot point above the steering box.
I will also need the 3 speed column shift top plate for the transmission. I have a stick shift top plate currently.
Thank you in advance for your help.
Robert Haserot
Portland, OR
I have a 3 speed transmission column shift cover. Would you like to trade?
I'm in the process of removing my column shift from a mid-68 FJ40 for a floor-shift 4spd...
How soon do you need the stuff?
I would love to. Let me get you a pic. They bent the stick because the transmission ended up under the heater box. I'm going to clean it up and post a pic later this afternoon.
Robert
I am in no rush, take your time. I have to work late today, so it will probably be tomorrow before I can get you a picture.
Kevin
Hello,
Robert Haserot
Portland, OR
Column shift is only designed to work with the I6. Seriously doubt you would get it to work with a V8. Just sayin.
Every time I give a time estimate I am wrong. I would like to get the drive-train together in the next week or two. (What that probably means is I actually need it next year.)
Without rushing your own project when do you think the parts might become available?
Thank you!
