so this is a bolt on job with no welding of the lower frame bractetry?
so with moving the front axle forward a bit and moving the frame bracket back you have extended the front arms 8 or 10 inches?
Some day we'll be able to buy a skid plate/cross member/3 link kit like the long arm kits for TJ's. I really like your mostly bolt on bracket design. Somebody should be working on selling a skid plate/cross member/bracket kit. The 80 market is growing all the time with these mall cruisers getting traded in.
Did you go with rubber bushings on one end of the links? Or Johnny Joints at both ends of all the links? Any noticeable NVH changes?
What would you have to change for a 4 inch lift? I keep thinking the tower on the diff would have to be lowered for a 4 inch, due to oil pan and motor mount clearance. I'd probably need to lower the lower links too, and lose some ground clearance, to keep the same vertical separation for axle wrap.
Any mods to the steering for all this flex?
How much did you increase the wheel base?
Mike,
So with this kit can I run 33's?
-Ammo
I have a CDL switch and a rear locker I have TRUE two-wheel drive which suits the "trails" in SoCal just fine (you know them...Sunset, Rodeo, Santa Monica, Wilshire)![]()
Sorry, NVH is Noise Vibration and Harshness. I was just wondering about the ride. Any noticeable changes in forces or vibrations transmitted to the cab? I've been trying to design a 3 link for mine, and I keep wondering if I should have rubber bushings at one end to absorb vibes. I'd rather not, but not sure if it would be an issue.
Did you use any kind of CAD (or suspension program) to setup the link geometry? I've been trying to use a constrained (stick figure) sketch on CAD to simulate the movement of the links, and resulting drive shaft angles, caster, etc. From dragging the sketches around, I noticed that it would be really easy to screw up the placement of the links so that the axle would rotate a lot through the suspension travel. Its a little hard to find a geometry to be confident in.
Would you mind giving your mounting points and link angles for reference? Might be able to estimate it from the pics.
Did I read it right that the lowers are triangulated at 10 degrees (both sides)?
any more updates on this project? steering? road manners? highsteer? flexed out?
more pics please
