3-FE Engine Hose Identification Help
Salt Lake City, UT
This weekend I was replacing my front sway bar bushings and noticed a hose that looks like it will blow at any moment. It is falling apart and soft and gummy. I have a road trip next weekend, and want to replace it before the inevitable happens. I searched mud and google, but could not find the hose. Tracing didnt leave me any certain answers, it is either Oil, Transmission, or Coolant (obviously), but I dont know what to drain, to take it off, to see what inside.
Please help ID. This photo is taken looking up, just behind the right front wheel, so that is next to the oil pan on the passenger side.
That looks like it's going to a trans cooler or oil cooler. Can you trace it? Or just unhook it and see what comes out, then you'll know. :)
@jonheld probably knows just by looking at this picture...
Tracing to the back of the engine gets a little lost around the bell housing. It isnt obvious that its trans line to a cooler since those are smaller and present. This isna pretty wide hose which makes me think coolant. It seems to bridge from a harf metal tube to somewhere in the front, but I cant seem to accurately follow it up front. I am not even sure where to start looking for a part number if I cant for sure say what it does. Worse case Ill extract some fluid using a syringe.
Thank you @Godwin, I was able to find a thread on mud about changing the oil cooler hoses (https://forum.ih8mud.com/threads/an...er-hoses-without-draining-the-coolant.788643/) using that info. Jonheld chimed in on that, but it does not give a part number. Seems like it is a pretty simple bend to the hose, anyone know if I can just cut a piece of hose off of the same diameter or is there an actual part number for this? And are there more? That thread I noted says hoses, which makes me think there are more than just the one I circled in the photo.
I found this on one of the 40 Series threads about a 3FE conversion. It appears to be 3 hoses. I think the hose on the water pump is good, I just replaced most of those last summer, so that leaves the back two. If anyone happens to know part numbers, that would be a great help.
Any of the parts guys on this forum will know what you need if you ask them. That specific hose deteriorates over time due to constant oil baths from changing the oil filter.
Jon, Any chance that this can be changed without totally draining the radiator? Mine needs to be changed badly.
I changed mine before my Moab trip in 2012. It was original and in poor shape. IIRC I decided to do a drain and refill of the radiator at the same time because it just made sense to do it that way. Got a face full of coolant and assorted other goodies as well. Good times.
How quick are you?
Nah you'll lose a bit but be quick, have new hose clamps set up on the new hose and you'll get it.
Sorry for reviving this, but OEM part number 90445-24039, the hose from the water pump to the oil cooler pipe, is discontinued. What hose are you using to replace this?
Thanks beno!
