Well Hoss, this thread developed from another so maybe you don't see any connections.
Also, springs are springs so sticking them on any number of trucks will result in different "inches" of lift. That's why it won't be 3" or 4" or whatever. If you'd installed a bunch of springs or seen and measured the "lift" on a bunch of 80s you'd get that.
Also, I live in SoCal too, family is in PA, WV and OH so I've wheeled my truck and driven it there numerous times with wife, kid, dog, etc as well. I lived with it in TN and wheeled it there too. Every year we go back to CO where we lived and my daughter was born and wheel it there and in So UT on the way there and back. Oh, and it's my only vehicle so I drive it for work too mostly on the highway then on job sites. So what?
My experience with drop brackets is what Man-a-Fre and Steve-O has posted. I read it with interest. I suppose Steve doesn't post this stuff for advertising but to generate interest, comments, and possibly derive new ideas. This is a discussion and I think I've brought up valid points on the short-comings of the drop brackets (1. lower clearance, 2. relatively non-adjustable, 3. frame mounts vs. axle mounts). He seems to do just fine defending the good points of the system but it would still be nice to see some numbers of what the caster was before the drop brackets and then put some J-springs, spacers, etc and check the caster again to see what effect the drop brackets had. Also, it would be nice to see some wheeling pics or anecdotal info about wheeling a really rocky trail where under body clearance was an issue. How does it do? Do the drop brackets really act as sliders, etc. This HAS been discussed before in previous threads so I guess I just wait for something NEW to be introduced.
Since this was not supposed to be a brand loyalty thread I never brought up Slee's stuff or compared MAF's stuff to anything except maybe when I mentioned Rick's plates. I have run the truck completely stock on road and trails to the point I destroyed the running boards, then ran an OME lift (2.5") with no caster correction bushings, then ran that with CC bushings, then added spring spacers, then went to taller springs, then added adjustable panhards, then added adjustable rear uppers, then added slotted adjustabel caster slots in the front of the front control arms, then added CC bushings to the rear of the front control arms, then added 6" springs, then added Outback AWR control arms with adjustable length, then added spring spacers. So whose brand am I trying to hold up and say is best?
I think I'm skinning the cat in plenty of ways and don't mind seeing other ways but you're still driving around on a stock suspension piping in here like you know MAF's kit is the cat's meow. It truly might be and I'm not going to say otherwise but I just want to have someone buy it, install it, and then let's go wheeling
Isn't that what it's all about? Well other than the hokkie pokkie....
BTW, lay off the caffeine
