3.70, front 8" reverse rotation gears
Washington
Are there 3.70 gears for the front 80 axle? I can find 3.70 rears but not the fronts. I have heard rumor of the Toyota diesels using 3.70 gears but I haven't found any facts to back it up. Since I am going to be doing front and rear limited slips I figure I might as well swap out the R&P if I can find a 3.70 front gear set.
For those of you that have swapped in ARB's, etc and did not regear, how did your gears look at x number of miles? I guess if I can't find the 3.70 gears I would just try and reuse my stock gear set since they have 170k miles and my gear oil is always spotless and never a hint of metal on my drain plugs.
Having a Harrop installed now and the stock gears with 115K look nearly new to me.
My 3.54 gear install thread had pics of 2 sets after 230k plus. One looked great one was a little off but still.in the acceptable range. No noise or anything.
Marks4wd has the 3.7 gears same place I got my 3.54. Exhange rate right now is good there site gives you the USD estimated shipping right on. About a week to get them DHL.
Phew, $550 USD even with a good exchange rate. I guess I will be sticking with 4.10's
