2UZ Starting Help - Struggling to Cope
Hi
I am experiencing the same starting issue with my LC100 V8 2UzFe 2006 model.
I have changed almost everything as mentioned in this forum. Except the ECU and the problem still persists. I even changed the Head gasket but the problem persists.
My vehicle is 120,000km driven only.
Me mechanic has tried many things and even shown to experts at toyota but nothing helped.
Vehicle start perfectly fine when it’s cold or even starting after days. But if you start it after 15 minutes or more of a drive when it’s warm, it tries to start then misfires and starts.
Otherwise runs perfectly fine.
Please suggest if you all were able to fix your problem.
Hi All,
I've been having a starting issue on my 2000 Tundra, V8, 4WD, Access Cab. Before this, it was sitting pretty at 300k miles. The issue I am having is starting when hot, or driving for a while and then starting after the truck after it has sat for 1 - 4 hours. Cold starts in the morning are fine - it will crank over 6 or 7 times and fire right up. Hot starts it will crank 1 or 2 times, act like it's gonna stall, and then slowly start up.
This whole saga started when I noticed hesitation when accelerating under load. I ignored that for a time and, since it wasn't throwing any codes, I just let it be. Eventually, it turned into a P0171 (system too lean, Bank 1). It was at that moment that I decided to do some "routine" maintenance. When I say routine, I mean routine for a 300k mile truck. Just thought I'd give it a glow up so it could serve me for another 10 years.
I replaced the fuel pump and fuel sending unit first, which fixed the hesitation when accelerating and the P1071 code.
After that, I replaced the fuel injectors with 12 hole injectors (yeah, I may have been duped, I don't know yet), intake manifold gaskets, and entire throttle body and gasket. I replaced the valve cover gaskets, spark plug tube gaskets, spark plugs, ignition coils, pcv valve and hose. It is at this time that my starting problem began.
I went on a journey to figure out what the hell was going on, and I still have not reached the end. I then subsequently replaced the MAF, crank position sensor, fuel filter, fuel supply lines, engine coolant temperature sensor, cleaned up the battery terminals and grounds around the engine bay, fuel pump resistor, starter relay. And, I even went back in and replaced the starter motor again and all new intake manifold gaskets, again. I even replaced the o-rings, grommets, and insulators on the already new fuel injectors.
Yeah, I have shot the parts cannon at this and am ashamed of doing so, but no level of diagnostics I have done have revealed a problem. When it drives, it drives great and feels amazing. It's just this damn starting issue that has me stumped. I have hooked up a vacuum gauge at operating temp in idle several times and it reads dead steady, at 16, so I don't think it's a problem with vacuum or pistons or anything.
Can anybody PLEASE help or give some advice? I just don't know what to do anymore. Even the dealership and some reputable toyota mechanics say that there is nothing wrong, but I know my truck and how it used to be.
Hi
Is your issue of starting when the vehicle is warm, resolved yet?
I have a 2006 Land Cruiser 100 series and it cold starts and runs perfectly fine but takes longer time to start when it’s warm or after a 15 mins or more drive it doesn’t start properly. I have the same problem as yours.
Please help.
